Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#561 |
Finished Parameter implementation.
Documentation snippet: Optional parameters can be set by pressing the infrared remote key 0 three times within 2 seconds to go into parameter mode. This is acknowledged by 3-time blinking of the LED. To set a parameter, the parameter ID must first be selected from the table below. The parameter value is entered in 3 digits. The parameters are then permanently stored in the flash of the microcontroller. This is acknowledged by 4-time blinking of the LED. Cancellation is possible at any time by pressing the rotary-encoder button continuously for 3 seconds, this is confirmed by the LED flashing 5 times. To set all parameters to default values, use parameter id 9 and value 999. Example: Set Volume Offset L to 12 1. Press key 0 three times 2. Press key 2 (Volume Offset L) 3. Press key 0 4. Press key 1 5. Press key 2
Muses Volume Kits available https://www.diyaudio.com/forums/swap...es-volume.html |
#562 |
Impressive... is also the display dimmbar and/or going into dark mode after a certain delay ?
#563 |
Hi Claude,
the Version is without a display. Daniel
#564 |
OK... is the display an option or won't it be?
With all these features it could be nice to know where you stand by a glance, so one wish it, eventhough a later add-on? MFG Claude |
#565 |
@meldano I’d love to use your new version as a pure volume control for balanced XLR input. No source selector, no screen. Would it be possible to do so?
#566 |
thanks! Yes, it works fine without the Input Selector Board. It is only an option. Daniel
#567 |
Great! Looking forward to your final revision. I suppose the input impedance is 20Kohm?
#568 | |
Mark Micro Seiki DDX-1000>Pearl 2>BA-3 FE>F5>Mirage OM-7 Towers |
#569 |
I like these ultra low noise regs in combination with the muses.
For other audio circuits I didn’t like the TPS7 or LT30. BTW: My Muses v2 works fine and I will order the input selector boards to the end of this week.
#570 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
KIC9482F electronic volume control | madanthonie | Parts | 1 | 10th January 2014 07:07 PM |
Electronic volume control idea | Elvee | Analog Line Level | 3 | 9th August 2011 09:24 PM |
Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 08:20 PM |
Noisy electronic volume control SU-G95 | Mailliw | Solid State | 0 | 23rd April 2007 08:40 AM |
New To Site? | Need Help? |
