MUSES 72320 electronic volume
Old 19th December 2018, 12:53 PM   #411
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
If you still have it, i want to buy it
Meldano
If you have the volume control i want to buy it
Old 6th January 2019, 04:48 PM   #412
Hikari1 is offline Hikari1  United States
I am thinking about buying one of the kits from academy audio.
Iam totally confused as to whether a buffer is needed after the pot...the muses will be in front of a jfet input preamp with 47k input impedance.
Internet pics show what might be a jfet follower after the muses pot on the xp30...but why? Surely the input impedance of UGS is almost as high as a complementary jfet follower like b1 rev2.
Old 6th January 2019, 04:48 PM   #413
meldano is offline meldano  Germany
Meldano
Yes, Please write a pm
Muses Volume Kits avaible
https://www.diyaudio.com/forums/swap...es-volume.html
Old 8th January 2019, 09:41 AM   #414
zenmastering is offline zenmastering  Canada
Yes, use a buffer after the pot. The Academy Audio offerings have a place on the pc board for a dual FET op amp of your choosing to function as a buffer.
You should not need a buffer on the input side unless you have an unusually high source impedance feeding the Muses IC.
Old 8th January 2019, 09:42 AM   #415
$$ sent via PayPal for one stereo-balanced kit. Thanks! (PM sent, too.)
Graemme
Old 15th February 2019, 03:01 PM   #416
Theodosis O. is offline Theodosis O.  Greece
Is the quality of the power supply (+/-15V, +5V ) critical for this application ?
Is a PS with LM317/337 enough ? or it better to use shunt PS like Salas BIB ?
Old 15th February 2019, 04:00 PM   #417
NicMac is offline NicMac  Italy
NicMac's Avatar
Or maybe one of Jan's SilentSwitchers - works great for me
Old 15th February 2019, 04:02 PM   #418
It likely depends if you are using the opamps or not. If not, probably not critical.
Old 15th February 2019, 08:00 PM   #419
I am not using opamps.
I would like to use it with Salas dcg3.
Old 15th February 2019, 08:36 PM   #420
Why? I understand that the Muses IC shows more channel imbalance as the input impedance goes down. But at 47K it looks pretty good.
My preamp has a 47K input impedance. My buffer has a 100K input impedance. Not much difference.
MUSES 72320 electronic volumeHide this!Advertise here!
KIC9482F electronic volume control madanthonie Parts 1 10th January 2014 06:07 PM
Electronic volume control idea Elvee Analog Line Level 3 9th August 2011 08:24 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Noisy electronic volume control SU-G95 Mailliw Solid State 0 23rd April 2007 07:40 AM
Copyright ©1999-2019 diyAudio
