LF03 discrete opamp
LF03 discrete opamp
Old 5th June 2012, 07:43 AM   #11
Brett is offline Brett
Brett's Avatar
Are you going to offer boards for this? I have an interest for a specific application.
Old 5th June 2012, 09:42 AM   #12
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Bare board sets (2 + 1 PCBs) and kits (PCBs + parts) are available. Please PM me or email me at siva dot chander at gmail dot com.
(Note that there are changes to the schematic that require a track cut, one additional reference diode per channel, and some changes to component values. These changes allow operation over a wider range of rail voltages (+/- 3V to +/- 18V) than the original circuit, and a consequent reduction in GBW product at low rail voltages.)
Old 4th September 2012, 04:10 PM   #13
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Hello,hows it going with my order?Been a while now..
/Åke
Regards Åke
Old 6th September 2012, 09:31 PM   #14
Ryssen's Avatar
I got an e-mail telling that my order is ready for delivery.
/Åke
Regards Åke
Old 9th September 2012, 07:40 PM   #15
A couple of pics of the current LF03 Rev C module as well as a Rev C assembled on the original board with track cuts:
Old 26th December 2012, 09:57 PM   #16
Ryssen's Avatar
You got an email
Regards Åke
Old 25th September 2013, 05:46 AM   #17
Update: SMD LF03 versions have been prototyped and are fully functional - I'm evaluating the audible sonics, which seem to be similar to the previous through-hole version, the LF03c. The SMD single, the LF03s has been tested working in a MyRef Rev C in place of the LM318 monolithic opamp.
Pics of the different versions of the LF03, including the latest SMD version(s) - from left: the LF03c (through-hole dual), LF03d (SMD dual, derived from the LF03c topology) and LF03s (SMD single, which is the same as one channel of the LF03d and shares the same PCB):
Old 25th September 2013, 06:50 AM   #18
Link to posting on the vendor's forum offering the LF03s (DIP8 single) and LF03d (DIP8 dual):
http://www.diyaudio.com/forums/vendo...ml#post3644382
(These are general-purpose bipolar-input opamp upgrades, and have been widely used in I/V, line amplification and other small-signal and line-level applications, in addition to the LM318 upgrade in the MyRef Rev C mentioned in the posting. The most common application for the dual version is CDP/DVP/DAC line-amp upgrades.)
Old 28th September 2013, 07:34 PM   #19
sgrossklass is offline sgrossklass  Germany
It would be interesting to see some Samuel Groner style tests of these. The last time I was playing with discrete folded cascode topologies in simulation, results were rather disappointing.
Old 29th September 2013, 08:41 AM   #20
The LF03 is not a folded cascode, though I've built another DIP8 single (LF05) using a folded cascode - which sounds OK but not as detailed and well-defined as the LF03, which uses a base-driven differential VAS with a floating current-mirror - a bit like a bipolar-input Kaneda on steroids.
For Class-A discrete opamps, the measured distortion can be misleading - they often sound better than the numbers may indicate. Conversely, Class-AB monolithics often sound much worse than the distortion numbers indicate - the LM4562 being the poster child.
LF03 discrete opampHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
My discrete opamp udip Solid State 51 8th August 2006 07:33 AM
Copyright ©1999-2019 diyAudio
