AD797 Preamp based on stolen trademark
Old 2nd July 2020, 06:25 AM   #101
ginetto61 is offline ginetto61  Italy
Sometimes the secret of great sound is also in the details (i.e. parts selection). For instance if panel sockets were not important there would not be market for high quality panel sockets.
One example ... i suspect the volume attenuator used in the real MBL is very very high quality. A precision part.
I am a little obsessed by volume pots lately. I have the feeling that some on ebay are even fake parts.
I would look at a stepped attenuator with a decent mechanism and resistors for good sound.
“And is it any wonder That the monkey's confused” ― Roger Waters
Old 3rd July 2020, 09:27 PM   #102
keilau is offline keilau  United States
Originally Posted by gigigirl View Post
Well I received my built up board last week, with the JRC5534DD (presumably fake) op-amps fitted.
I fitted it to my case that previously had a JC-2 in it. I am still waiting for my AD797 op-amps to arrive so I will not do any serious listening until I get them
Anyway after a couple of days of burning in I decided to give it a listen though my Pass H/P amp & AGK701 cans, How did it sound, well not bad at all, certainly better than the JC-2 that was previously being used.
Will give a further update when the AD797's arrive.
Cheers
If it sounds better than the JC-2 with only the NE5534, it has potential.
Did you consider replacing the regulator circuit with an outboard low noise PSU? You can get this board using 317/337 with an opamp de-noiser for about $10. See this post at the power supply forum.
What is this opamp doing in this power supply schematic?
Old 3rd July 2020, 11:12 PM   #103
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
And yet your picture shows some very durable but average sounding rhodium sockets
Old 4th July 2020, 02:36 AM   #104
gigigirl is offline gigigirl
Default Replacing power supply board
Hi, Yes I have thought about that & also upgrading what would be a fake Alps Pot.
However the board shown, which I had not seen before) outputs DC, So I take it I would need to locate were the DC output from the build in board was. Or can you just wire in a +15 / -15 DC supply to the place where you would normally wire the transformer to?
Cheers
Old 4th July 2020, 03:21 AM   #105
Cheers
I will take all active components (opamp etc.) off the socket before surgical operation.
Remove the rectifier diodes, main filter caps and anything else between them. Make a red jumper from one of the AC-in (use the rectifier hole) to the positive hole of the positive filter cap and a black jumper from the other AC-in to the negative hole of the negative filter cap. Leave the small caps and other components after of the main filter caps in place.
Check continuity from the new +DC in to the opamp + supply pin. Any of the opamp will do. Check continuity from the new -DC in to the opamp - supply pin. If good, you are ready for action.
Old 4th July 2020, 03:27 AM   #106
Rhodium is a soft metal meant to improve electrical contact. It needs to be on one side of the plug or the socket. The very, very thin layer of rhodium should not have any sound of its own. It may not be exciting, but it is neutral.
Old 4th July 2020, 05:18 AM   #107
Hi, Thanks Keilu, But that's way above my pay grade. I have very basic electronical knowledge & Skills. Thanks why I normally buy build up kit's.
Derek Derek
Old 5th July 2020, 09:16 PM   #108
Derek Derek
I understand. Taking components off an assembled PCB is not my favorite hobby either.
For my line level preamp, I use a clone of the Sugden DAC line output board which is very faithful to the original. I have been using a twin TL1083CP regulator PSU for the past year and am waiting for the opamp servo de-noiser PCB to replace the power supply.
LM317-LM337_LF353ServoRectifier.jpg LM317-LM337_LF353ServoRectifier_picture.jpg
On the lineamp board, I replaced the NE5534 with LME49710 which is much cheaper than the LD797 and very good for line level.
Old 6th July 2020, 01:55 AM   #109
Hi, Just spotted this for under $60, From what I can tell, this may be suitable for the power supply you suggested
HIFI MBL6010D Preamplifier Preamp Board Tone adjust Fit For NE5532 NE5534 OPA 228243292918 | eBay
Cheers
Old 6th July 2020, 02:01 AM   #110
Cheers
For a simple board with 4 NE5534 and 2 NE5532, the $60 price tab seems way too high. Did you check AliExpress? It seems to be unbalanced in and out only. No balanced port!
What potentiameters and how many does it include for the tone control?
AD797 Preamp based on stolen trademarkHide this!Advertise here!
Stolen Trademark Amplifier from Jim's Audio on EBAY crazycloud Solid State 575 6th August 2020 04:00 AM
AD797 in preamp: need help TB Analog Line Level 20 15th September 2010 08:47 AM
AD797 in preamp: need help TB Chip Amps 2 9th September 2010 04:12 PM
interesting little IC (AD797) preamp dorkus Solid State 31 3rd December 2008 05:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
