Loudness stage
Loudness stage
Thread Tools
Old 20th October 2020, 02:27 AM   #61
jfetter is offline jfetter  Costa Rica
Loudness stage
I came across the Dual and Braun while looking for Dieter Rams designs. I think the packaging is excellent and if the outside is nice then following form/function the circuits must have sounded heavenly.. Simple and functional no more no less.
So I study the early designs. Braun, Dual , Telefunken, Philips and so on. I'll have to look at Grundig. Many companies attempted to copy Dieter Rams but it usually did look like a style copy, not quite correct. The early Sansui circuits are also interesting but not packaging. Some circuits I have adapted to valve-opamp hybrids. It is not difficult and the fft is exactly what I want.
The images are from BRAUN, BRAUN Hifi, Braun design, Thomas-Mathias Bock, Dieter Rams,Computer Graphic,
File Type: png Screen Shot 2020-10-19 at 8.09.58 PM.png (296.9 KB, 137 views)
File Type: png Screen Shot 2020-10-19 at 8.11.08 PM.png (176.6 KB, 137 views)
Old 20th October 2020, 05:19 AM   #62
ubergeeknz is offline ubergeeknz  New Zealand
Does anyone have a circuit to make use of a tapped volume control? I have an ALPS RK27 type (probably a clone) stepped attenuator with a loudness tap, I wouldn't mind trying a passive loudness circuit on it, so that it is active at lower positions only. Thanks in advance!
Old 20th October 2020, 01:04 PM   #63
Loudness stage
Originally Posted by nironiro View Post
This is 5 pin volume pot in Grundig SV 2000 amplifier.
Many Grundig models use that double loudness.
To copy/test the Dual loudness ckt a stepped attenuator can easily be made to operate as a 5 terminal volume control i'm thinking.
for ref here is sv2000 passive loudness volume ckt using Sziklai pair make-up amp. Its not switched so maybe less parts.
File Type: jpeg 4D710E80-FA1E-4433-AF87-19CED0E1DBB7.jpeg (397.2 KB, 129 views)
Old 20th October 2020, 01:12 PM   #64
nironiro is offline nironiro  Croatia
Stepped attenuator must be simple to made for that, if resistors are easy accessible.
Old 27th October 2020, 05:29 AM   #65
OK so in my case the tap seems to have a resistance from the input pin as follows:
1-10 : 47.5k
11-22 : reduces by ~4k each step, ending in 5.8k at position 22 (it's a bit more gradual to start, then reasonably linear until it reaches step 22)
Question is, how do I use this tap to create a loudness control? I feel like I'm missing something obvious. This is a 50k log taper attenuator.
Loudness stage-screenshot-2020-10-27-172832-png
Old 28th October 2020, 03:23 AM   #66
Loudness stage
my first try would be to use the grundig circuit on knee of your plot.
while the mirror knee gets the treble side.
if you do a plot from hi side of pot to wiper u see the mirror knee.
Old 28th October 2020, 05:35 AM   #67
Hmm @jfetter not sure that will work. As it is a volume attenuator with only one "tap", input, gnd, and wiper. And the main input/gnd/wiper is log/audio taper.
Old 28th October 2020, 06:40 AM   #68
Loudness stage
its a bank of resistors, so move the switch to knee position and look at switch contacts.
that point is the loud tap.
of course a wire must be soldered and brought out for the loudness ckt.
Old 28th October 2020, 08:40 AM   #69
Jonathan Bright is offline Jonathan Bright  Australia
Dear all,
This will be a bit frustrating for many people but if you have access to the JAES or are prepared to buy this article the following would seem to be a very neat solution for most needs. Its from 1976. It has variable break points for the bass region. Elegant, simple, cheap and highly effective.
Cheers, Jonathan
AES E-Library >> Practical Loudness: An Active Circuit Design Approach
AES E-Library
Document Thumbnail
"A loudness control fully compensated at mid and low frequencies has been designed for home use which can be aligned to match equal-loudness contours over about a 40-dB attenuation range. Using a linear potentiometer and an operational amplifier, the circuit can provide a smooth audio taper as well as a control of volume which is free of tonal balance coloration".
Authors: Newcomb, Jr., Arthur L.; Young, Richard N.
Affiliation: Langley Research Center, National Aeronautic and Space Administration, Hampton, VA
JAES Volume 24 Issue 1 pp. 32-35; February 1976
Publication Date: February 1, 1976 Import into BibTeX
Permalink: AES E-Library Practical Loudness: An Active Circuit Design Approach
Click to purchase paper as a non-member or login as an AES member. If your company or school subscribes to the E-Library then switch to the institutional version. If you are not an AES member and would like to subscribe to the E-Library then Join the AES!
This paper costs $33 for non-members and is free for AES members and E-Library subscribers.
Learn more about the AES E-Library
E-Library Location: (CD aes3) /jrnl6877/1976/7389.pdf
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 28th October 2020, 10:10 AM   #70
Figured it out now ... the amplifier is attached and it presents a low impedance relative to the 50k pot... hence it's throwing my measurements out. Of course it is just a center tap (at about 47.5k/2.5k). Which I can make sense of
Loudness stageHide this!Advertise here!
Thread Tools
loudness control maylar Solid State 15 29th July 2012 02:36 AM
Loudness experiences? Skorpio Solid State 24 27th July 2012 06:58 AM
The Loudness button 2litre Everything Else 15 25th November 2006 12:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
