Salas hotrodded blue DCB1 build
Old 18th October 2018, 01:07 PM   #5761
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by tribute View Post
Hi Salas, Thanks for the info, that should do the trick & quite unbelievably, cheaper than F/Bay.
Now sorry for the nob question, but normally I never, never work with 240 AC, How do I connect up the wires!!
Cheers
Its datasheet shows brown to live, blue to neutral (primary side colours to the mains plug).
Mains earth third wire from the plug just tie it to the chassis with screw and nut for safety.
Secondary side colours to the electronics:
Black and yellow put them together to the middle input of the board's AC connector.
Put red to one of its corner inputs, orange to its other corner input. No matter which.
https://docs-apac.rs-online.com/webd...6b815bd18d.pdf
Old 23rd October 2018, 05:12 AM   #5762
tribute is offline tribute  Australia
Hi Salas, Thanks for the connection sketch, did not see it on my link to the site. However now understand how to connect.
Many Thanks
Old 30th October 2018, 02:32 PM   #5763
keith1962 is offline keith1962
Apologies if this is answered elsewhere but I have not been able to see it.
I have the black Hypno boards. I am intending to use foil caps for the .22uF caps and the ones I am using have an indication for open foil end. Would it be better to connect this end to the + or the -, or does this not matter?
KR
Keith.
Old 30th October 2018, 03:17 PM   #5764
Salas's Avatar
If it matters in this case, the lower impedance point in the positive section is the (-) and in the negative is the (+) to orient the outer foil ends of those Vref bypass capacitors.
With bigger sized capacitors mainly, the outer foil becomes less susceptible to external interference when connected to the lower impedance side of the circuit.
Old 30th October 2018, 03:38 PM   #5765
Thanks for the quick response Salas. Understand that now and you answered it in the way I should have asked it ie. Which is the lowest impedance point on each side.
KR
Keith.
Old 20th November 2018, 10:33 PM   #5766
ThomasJ is offline ThomasJ  Norway
Hi all
I’m working on a balanced version of the DCB-1, with In-Select boards for volume and input control.
Is it possible to use a 2pole 6pos switch for input selection on two In-select boards?
Using one pole for each board, that is.
//Thomas
Old 20th November 2018, 10:38 PM   #5767
Salas's Avatar
Yes of course. The switch's two sections are electrically independent.
Old 20th November 2018, 10:53 PM   #5768
Thanks for your speedy reply!
Do you have any suggestions for a good “balanced” potmeter that could control both boards, or would I need to use two separate ones?
I see Alps used to make a balanced version of the RK27, but it seems like they don’t anymore.
// Thomas
Old 20th November 2018, 10:58 PM   #5769
Salas's Avatar
That one you should investigate or someone else will answer because I don't have info about it.
Old 20th November 2018, 11:04 PM   #5770
OK. Thank you
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Copyright ©1999-2019 diyAudio
