Salas hotrodded blue DCB1 build
Old 4th June 2015, 01:27 PM   #5001
saverior is offline saverior  Italy
Hi all,
I was quite happy with my dcb1 listening for a month and over very excellent sound quality.... but now something bad is happening!
Occasionally, after some hours of power on one of the Leds string (the one on the IRFP9240 side) switch off...and quite soon they switch on again....and everything is fine again...
Of course in the middle of this switch off/on sound is distorted and noisy
Soldering is ok. I double checked.
May be too much heat? (is quite warm now-days in Italy)
Suggestion on what I can check?
Tanks,
Saveerio
Old 4th June 2015, 01:44 PM   #5002
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Some intermittent LED in the string?
Old 4th June 2015, 01:51 PM   #5003
Salas's Avatar
Disconnect it from the stereo, power up. Tap those Leds one by one with a screwdriver, tap around the PCB near them and the relative Mosfets. Watch not to short something when doing that. Do it both when cool and when warmed up again.
Old 4th June 2015, 01:52 PM   #5004
No, no.
All five LEDS switch off at same time and then after 1-2 secs they switch on again!...
(may be useful to say that last modification was adding a blue led (on the proper place) and tapping off the bridge (from the power caps) the voltage for an extra (out of the board) LM7809 intended to power a little fan (but actually still disconnected from the fan!)
Old 4th June 2015, 02:01 PM   #5005
Salas's Avatar
If only one is switching then all will do because in series like chain links. There is a K170 sinking them to ground. That one can be suspicious also. I would change all 5 LEDS and the K170 if I could not focus on one intermittent component or one cold joint. I would also inspect the board vias and Mosfet joints because maybe little cracked when bolting the Mosfets to sink. Rework the joints for sure.
Old 4th June 2015, 02:16 PM   #5006
Ok thanks a lot Salas.
Actually also my suspects are about joints... this is my first "solder from scratch" board!...really one of the worst DCB1 realized I think BUT I still can't believe it works so well!
I'll do my checks and test for some days to see what happens
Old 4th June 2015, 02:50 PM   #5007
Salas's Avatar
Very important is your iron and solder. Use leaded solder, not ROHS, and temperature controlled iron if possible. Don't stay too long on a component when soldering, especially not on 3mm Leds which are sensitive to how much heat they can take.
Old 20th June 2015, 10:05 PM   #5008
kj123 is offline kj123  Canada
Default High offset on one channel, help
Hi
I just finished the DCB1 Black board (Tea bag kit) and I have a problem with the left channel offset at -85mv. Right is 2.3mv.
Vout is 9.94v and -9.95v. Voltage across the 10r is 1.8v on both channels.
Does the high dc offset mean the fets on the left channel are not closely matched? should l replace them?
Thank you
KJ
Old 20th June 2015, 10:21 PM   #5009
Salas's Avatar
Its the most probable cause to think of. Remove the suspect JFETs pair and confirm their IDSS if you can.
Old 20th June 2015, 11:22 PM   #5010
Thanks Salas... hmm, I swapped the fets. I put 2 that are perfectly matched on left channel and now I have 0.2mv offset but the right went up to 89mv. Can I just change the right pair? or do the 4 fets need to have close idss?
thank you
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2019 diyAudio
