Yet another Volume controlers and source selections
Old 6th May 2011, 07:02 PM   #521
tzya2 is offline tzya2  China
Wait PGA2310 LED version
Old 7th May 2011, 05:44 PM   #522
FarmTech is offline FarmTech  Denmark
FarmTech's Avatar
Send a message via MSN to FarmTech Yet another Volume controlers and source selections
Dont think ther have been a PGA2310 LED version ever , only lcd
Old 10th June 2011, 08:12 AM   #523
vzs is offline vzs  Europe
Default Annoying remote control issue
@FarmTech, Danzup
I'm using FarmTech's firmware version with the group-buy project from the first page (post #5).
I have a small but annoying problem with the universal remote control I just bought: Philips SRU1010 . Being a universal control I set the first Philips TV code for it then managed to learn the volume controller its IR commands.
Everything works but when I push once the Vol +/- it jumps two-three even four steps and rarely only one. I tried several other TV codes and re-learn the volume controller but without success. With another rc it works fine but I would like to have this simple one for it.
Any suggestions what should I try? I'm a programmer so if the source code is available I might find a solution for this issue.
Thanks, Zsolt
Old 10th June 2011, 11:30 AM   #524
FarmTech's Avatar
Hi Zsolt,
I think its the Remote thats send code to fast
What I can try do for you is add a small wait for VOL+ VOL- in the code
Is the version of DanZup software (FarmTech) with LCD and NO VU ?
addon zip
File Type: zip ATM16_SHT_R2R_LCD_FARMTECH_NO_VU_Wait_VOL.ZIP (17.8 KB, 170 views)
Last edited by FarmTech; 10th June 2011 at 11:43 AM. Reason: added test code for Vol to fast
Old 10th June 2011, 11:48 AM   #525
Originally Posted by FarmTech View Post
Hi Zsolt,
addon zip
Strange that the source selection works fine, one click one source. Only volume commands act strange.
Thanks for your quick reply/help! The version with LCD and NO VU is good. I had in plans to add VU as well, but that might never happen.
Old 10th June 2011, 12:02 PM   #526
FarmTech's Avatar
HI Zsolt,
let me know if this fixed your problem !
added wait x 4 for volume steps
Old 10th June 2011, 08:36 PM   #527
HI Zsolt,
Hi FarmTech,
Your mod fixed the problem. Thanks!
Old 25th June 2011, 05:19 AM   #528
hello,danzup
Forumul electronistilor • Vezi subiect - Controler selectie surse / volume atenuator
Attachment can not download, I would like to experiment with each program are
Old 25th June 2011, 09:23 AM   #529
dobrivoje is offline dobrivoje  Serbia
Originally Posted by tzya2 View Post
hello,danzup
If you want to download, you must register first.
You have to open two windows - one in Romanian and other translated. When you register, you can download and, in the same time, you read text in English in other window.
You can't register in translator.
Old 25th June 2011, 11:16 AM   #530
I have registered and active, but still can not download, always prompt attachment does not exist
Yet another Volume controlers and source selectionsHide this!Advertise here!
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2019 diyAudio
