How easy is it to convert from 110V AC to 240V AC?
Old 4th December 2007, 06:44 PM   #11
Nautillus is offline Nautillus  England
Since it has a strobe, it will have an adjuster. If it had a synchronous motor you would have had to change a pulley size. You can always make a strobe disk to suit 50Hz to sit on the turntable, or you could get someone to make a little strobe light operating at 120Hz - that would have pose value!
I ran an American Garrard deck in the UK for several years using a mains light bulb in SERIES with the motor. It glowed dimly and was only slightly warm - it was mounted inside the box. It's cheap and very easy to do, but you need to know what you are doing. You could have it outside in a nice desk lamp and make a feature of it! It's also possible to use a lamp dimming type circuit but they tend to be electronically noisy and may give you grief in the audio department.
Old 4th December 2007, 09:59 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Do a search on this forum and you will find an LED strobe I designed. It can do 50Hz or 60Hz depending on crystal choice.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th December 2007, 03:39 AM   #13
lt_texan is offline lt_texan  United States
And what a good and useful design it is!
Old 10th December 2007, 09:01 PM   #14
EC8010's Avatar
Glad you like it.
Old 10th December 2007, 09:22 PM   #15
es44 is offline es44  Denmark
es44's Avatar
Just for a quick check, this is usable:
Strobedisc
Best regards
Ebbe
Old 25th December 2007, 11:07 PM   #16
tubenut is offline tubenut  South Africa
tubenut's Avatar
Maybe I am thick but I have tried to search for Strobe by EC8010 and learnt a lot on threads read but no strobe circuit... Can anyone point / link me to the right thread?
Guillaume
Croak Audio Exploration
Old 25th December 2007, 11:13 PM   #17
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi spikeyfaz again!
I, remember I used 2.2 microF or 3,3 450V for 110Fan to 220V.
Regards zeoN_Rider
Old 26th December 2007, 04:42 PM   #18
EC8010's Avatar
I couldn't seem to find it either, so here's the circuit again.
Old 26th December 2007, 07:23 PM   #19
cuibono is offline cuibono  United States
cuibono's Avatar
FYI, with Lenco turntables, you can't move them across the pond- having a different mains frequency (50 v 60 Hz) causes the spindle to turn at a different speed (or something like that - the idler arm runs off the spindle?). I don't know if this will be a problem with your turntable, but maybe someone else does...
Old 26th December 2007, 08:14 PM   #20
kevinkr's Avatar
The motor pulley on the Lenco is replaceable for 50/60Hz operation. Hard though to get the part these days I'd imagine.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
How easy is it to convert from 110V AC to 240V AC?Hide this!Advertise here!
Pass X1 Pre:Voltage change from 110V to 220-240V rc5al Pass Labs 0 24th May 2009 09:45 AM
110v Transformers for 240v Puffin Solid State 6 18th April 2008 08:48 PM
Step down (240v - 110v) transformer for KingRex T10 amplfier johnm Class D 20 12th February 2007 06:47 PM
power conversion US to UK [110v to 240v] make Power Supplies 2 12th February 2007 08:53 AM
240V- 110V Marantz geddam Power Supplies 0 9th May 2005 12:04 AM
Copyright ©1999-2019 diyAudio
