kaneda preamp
kaneda preamp
Old 29th November 2018, 02:25 PM   #121
Zung is offline Zung  Switzerland
I wouldn't use an input cap.
Old 30th November 2018, 04:24 PM   #122
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Only use an input cap if you balance that with a similar valued feedback cap!
(See Hiraga's experiments with a "symmetrical" Kaneda power amplifier, I made one and it was lineair up to beyond 400 kHz without feedback, so the cap is not detrimental as such. )
└ la recherche d'un son perdu
Old 2nd July 2020, 08:19 AM   #123
triode_al's Avatar
Does anyone have a LTSpice model of the Kaneda (pre)amplifier?
Makes life easier.
Old 2nd July 2020, 12:36 PM   #124
triode_al's Avatar
Default KanÚda preamp by Jean Hiraga
here is my try on modelling of the KanÚda preamp circuit; I have not the appropriate LTSpice models of the old Japanese transistors so I have used some at hand. The 2SK170 might come close to the 2SK240 I have (but not in Idss but in this config that is of no issue I think, but I really should use a model for the 2SK30AGR. [Who has that??]
I used generic transistors instead of the Japanese ones. They probably fit the picture.
The harmonic degradation is a charm to see, and this is at 14 dB out (0 in)
I will try to use different output device.
Old 3rd July 2020, 08:45 AM   #125
triode_al's Avatar
I found a good 2SK30 model and here is the result:
No low pass in the feedback yet.
A formidable result. 0Hz - 640 kHz
I think that using the 2SK170 (I have the 2SK240 for the RIAA) should probably require an adaption of the R1, R2, R4 resistors in the input section to get the same wide bandwidth result.
Distortion: at 6 dB output, -100 dB second, -120 dB third, no higher harmonics.
This is thanks to EUVELs nice sim settings I can assure you.
When adapting the Maison de l'Audiophile boards I have had similar results by the way (I shortcircuited one line board populated with the original transistors, impossible to find the same; choose to change to older metal can types.
  • Tested these older transistors a lot. On the testbench, without compensation, a simple high band without any peaks. So indeed it is possible.
Old 3rd July 2020, 11:17 AM   #126
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
kaneda preamp
Could you share the 2sk30 model?
Old 3rd July 2020, 12:32 PM   #127
triode_al's Avatar
I have used this LTSpice-model, that holds a section for the different versions; Hiraga requiring the AGR version:
*2SK30
*id(R 0.3-0.75 / O 0.6-1.4 / Y 1.2-3.00 / GR 2.6-6.5)
.model 2SK30r NJF(vto=-0.8v beta=0.75m lambda=0 cgd=2.6p cgs=8.2p
+ dev 10% LOT 60%)
.model 2SK30o NJF(vto=-1.1v beta=0.75m lambda=0 cgd=2.6p cgs=8.2p
+ dev 10% LOT 60%)
.model 2SK30y NJF(vto=-1.8v beta=0.75m lambda=0 cgd=2.6p cgs=8.2p
+ dev 10% LOT 60%)
*2SK30AGR
.model 2SK30AGR NJF(vto=-2.8v beta=0.75m lambda=0 cgd=2.6p cgs=8.2p
+ dev 10% LOT 60%)
.model 2SK30atm NJF(beta=.768m vto=-2.70 cgd=2.6p cgs=8.2p dev 10% LOT 60%)
* CQ 1988/7
Old 4th July 2020, 06:20 PM   #128
bluevas is offline bluevas  Indonesia
Hello Al,
please try this model :
.MODEL 2SA1316 PNP (IS=10.1F NF=1 BF=910 VAF=161 IKF=60M ISE=1.11P NE=2 BR=4 NR=1 VAR=20 IKR=90M RE=3.15 RB=12.6 RC=1.26 XTB=1.5 CJE=45.5P VJE=1.1 MJE=.5 CJC=14.6P VJC=.3 MJC=.3 TF=3.18N TR=2.21U Vceo=80 Icrating=0.1A mfg=Toshiba
.MODEL 2SC1213 NPN
+IS=210.0E-15 BF=150 NF=1 VAF=20 IKF=500.0E-3 ISE=130.0E-12
+NE=2 BR=25 NR=1 VAR=70 IKR=240.0E-3 ISC=1.650E-9 NC=2
+RB=700.0E-3 IRB=20.00E-3 RBM=816.0E-3 RE=125.0E-3 RC=26.00E-3
+XTB=0 EG=1.11 XTI=3 CJE=270.0E-12 VJE=680.0E-3 MJE=332.0E-3
+TF=1.5E-9 XTF=20 VTF=100 ITF=9 PTF=0
+CJC=54.50E-12 VJC=500.0E-3
+MJC=373.0E-3 XCJC=1 TR=1.000E-9FC=500.0E-3 KF=0 AF=1
With this models I have close value at Q1 collector voltage 602 mV, trim R3 value about 9104 ohm then I got the same voltage at Q2 collector.
I played with your asc file and I change this .four {Freq} V(VUIT) 5 5 .
Have a good day.
Best Regards,
Josh
Old 4th July 2020, 06:23 PM   #129
oops, i use this model
.model 2SK30ATM_GR NJF(Vto=-2.4 Beta=0.77m Lambda=1m Is=10f Isr=100f Vk=100 Alpha=10u Rd=30 Rs=30 CGD=9p CGS=9p Pb=0.3 M=0.38 mfg=TOSHIBA)
Old 4th July 2020, 10:00 PM   #130
analog_sa's Avatar
kaneda preamp
Thank you!
kaneda preampHide this!Advertise here!
ic opamp = Kaneda ? rumors Chip Amps 0 9th January 2009 09:16 AM
Why is the choke backwards in the Kaneda preamp? leadbelly Power Supplies 2 6th February 2008 04:15 AM
Kaneda hybrid preamp error ? coresta Tubes / Valves 3 23rd May 2006 04:07 AM
Kaneda Pre-amp? RichJones Solid State 0 7th March 2003 01:48 AM
Kaneda Preamp Lisandro_P Solid State 5 21st November 2001 03:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
