Hi there,
As anyone listened to this amplifier ?
It's a 70w per chanel amplifier amp, that seems to have the same kind of "phylosophy" than ZHAOLU DACs (cheap + good sound).
http://www.zhaolu.com/products/s60/s60.htm
toroidal snubber
4 X 10 000µF 50V main caps
use of Elna Silmics, Cerafine, 1% metal resistors
good quality relays
2SA1943 & 2SC5200 power transistors
discrete (?) gain stage (seems like on the pics)
2 X 70W RMS (8Ohm)
frequency response: 10Hz-60kHz (+/- 1dB)
SNR > 90dB
Distorsions: < 0,01%
output impedance: 47 kOhm
output level: 300mv
3 RCAs inputs + 1 USB
USB is only for the optionnal USB DAC (PCM 2707 + AD1852) that you plug inside the S60.
The mains specifications come from a friend in HKG.
toroidal snubber
good quality relays
2 X 70W RMS (8Ohm)
SNR > 90dB
output level: 300mv
