Zenith 12" alnico cabinet suggetions
Any suggestions for a cabinet design using 1960's Zenith 12" alnico woofers? I have used them in open baffles as per J E labs design, loved the sound but to bulky for my living room.
Re: some specs.
There should be another number. What volume is the "standard" box? Other numbers?
dave
sawdude said:Zenith 12" #49CZ970. my test gives FS of 55HZ and standard box 100HZ.
dave
more numbers
Zenith 343204, Std. box volume I used is 1.25 cu. Feet. These are only specs. I have.
Re: more numbers
An actual Zenith made- Zenith speaker (that is what the 343 tells us), that is a 1st for me 🙂
The data you have collected is not really sufficient to tell us much.
dave
sawdude said:Zenith 343204
dave
