When replacing a few caps in my Onkyo A-809 I realised that a leaking cap has destroyed a Zener diode, so I'm looking for a replacement for a MTZ5.6B zener diode. I know basically nothing about zener diodes so would really appreciate some guidance. I'm assuming the voltage should be 5.6v, but what does the 'B' in MTZ5.6B stand for?
Looking at Mouser and Digikey there seems to be quite a lot of different 5.6v zener diodes, but I have no idea what I'm looking for. Please help!
The zener is D902 on the diagram here
Onkyo A-809 Manual - Stereo Integrated Amplifier - HiFi Engine
Many thanks
Many thanks
It is a standard 5.6volt 500mW zener. If all else fails a BZX79C5v6 will do unless SMT and then it may be a problem fitting it.
Zener Diodes | RS Components
or SMD
or SMD
The B means 5% tolerance.
Be careful to get the right package/footprint part.
