Recently couple of rats have invaded my house and one of them even dared to enter the subwoofer.
And here is the result:
ImageShack Album - 6 images
From then, ALL the satellites and control pad is working totally fine just like new ones...EXCEPT the subwoofer.
You can see the condition of the subwoofer in the pictures.
I took the subwoofer to the local repair shops(as the speakers are more than 2yrs old and hence out of warranty).
They replaced some of the damaged capacitors and wires..but none of the 4 repair shops to make the sub functional again 🙁
Now how can i repair the sub myself..? Or can anyone tell me any good repair shop in Bangalore(India) who can repair it without fail...
Cheers.
Cheers.
im3164q.jpg shows 1 unconnected red wire
Where does this go to and where should it be connected to?
When you say all the satellites are working do you mean they have sound and the only problem with this is that there is no sound from the woofer?
in img3165m.jpg i see on the right something that looks like 2 blown caps , very hard to make it out on the image. and two cut wires.?
was these before or after the repair shops "replaced" the caps?
these pics r old...all those capacitors and wires are replaced and connected...
but still no result 🙁
Has the driver been replaced, too?
If that's gone open circuit, you won't get any output... Test it with another speaker or something.
Nope. Driver is not replaced. But since it is not 100% damaged, i was expecting atleast some minor noise from the sub to tell that the circuit is working...
Just give it to your friendly neighbourhood computerwalla.
Logitech is a common brand, they'll fix it up for you in a day.
I did that..and still sad results 🙁
I even gave it one of the biggest and most sophisticated electronic repair center...and they couldn't repair it! :!
If the voice coil itself isn't working, you could damage the amplifier trying to use it. A short circuit on the output will kill most amplifiers.
If the driver has gone open circuit, you won't get any noise out either.
Chris
MAJOR UPDATE:
I had given it to a big enough service center..they took 15 days and Rs.1600 to repair and got back the product today. They replaced an IC and reconed the driver.
But all i can say is...i'm dissapointed
Now i'm totally pissed off and don't want to spend anything more on this. Looks like i have to live with no (almost)BASS music and movies :/
After the repair, there is very low bass...do you think i can improve it if i replace the driver with something like this: Rockford Fosgate P1S810 - 10'' 300 Watt 8-Ohm Subwoofer ?
Though the sub works...its nowhere near what it used to sound before An externally hosted image should be here but it was not working when we last tested it.
That guy said..they need to replace 2 more ICs to get the original sound and it cost 2k more....Now i'm totally pissed off and don't want to spend anything more on this. Looks like i have to live with no (almost)BASS music and movies :/
- Subwoofers
- Z5500 Subwoofer dead(with pics). How to repair?
