Hi everyone, bought a faulty AX2 receiver hoping for an easy fix. Have soldering skills, searching google skill, but very little experience actually repairing stuff
So far no luck with protected/unprotected DIAG using "power", "effect" and "6ch input" - the thing just stays off. Also no relay click and no obvious blown/damaged parts, fuses are ok.
This guy doesn't have a common Yamaha's standby power issue as it has much simpler power supply implementation from what I've learned so far. Downloaded a service manual, tried to check sub voltages (page 63) and found them faulty (mine are green):
Opened the relay cover, it looks clean. Made several blind guesses by iteratively replacing c311, c315 and c318 - no result (circled in red, returned back to original eventually):
This is quite far from open book reading for me as you might already noted
What should I do next? Any help would be wonderful. Thanks!
