Well, this amp was built in `96.
Nicely built, with 2 transformers, some Elnas and mostly ceramic caps.
I like how this amp sounds, but i think it can do better.
My first and obvious ideea is to change the 2 large reservoir caps. They`re 6800uF at 56V, a small to fair value I guess. Even my CDP has a larger reservoir cap ( 10.000 uF
). I have 2 Russian 15.000uF/80V caps next to me, doing nothing. But this is this enough ?
In the next part, I will remove those 2 ceramic caps at the CD-P input.
And afterwards, I dont know.
That`s we`re you guys come in. Help me improve this little beast.
Good news:
Purchased 2x31000uF Sprague capacitors.
http://i26.tinypic.com/otho8y.jpg
http://i30.tinypic.com/10d5xms.jpg
Damn, cannot edit.
Measured the main transformer voltages.
~35,5V in IDLE
~35V in LOAD
And this gives us a theoretical voltage in VDc
~50,055V in IDLE
~49,35V in LOAD
If we include the diodes dropout (which i didnt calculate) i think (theoretical) we will have ~ 48V in LOAD.
Pretty close to my 2 Sprague capacitors.
What do you think ?
~35,5V in IDLE
~35V in LOAD
~50,055V in IDLE
~49,35V in LOAD
What do you think ?
http://i32.tinypic.com/2rfpiqe.jpg - number 19
and those 2 chemis:
http://i26.tinypic.com/1sb6gk.jpg
number 14 and 15.
and those 2 chemis:
number 14 and 15.
I`ve searched for parts that might be changed to gain some improvements.
The first thing, is the bridge rectifier. I might change this to four Schottkys and bypass them with 0,1uF ceramic. Before the bridge I`m thinking about putting some coils and 1Ohm resistors.
Next to the Power Transistors I`ve spotted some resistors that might be changed: 2x47O, 2x560, 2x47K, 2x100K, 2x6,8K, 4x5,6K. There are no pots. The collector-emitter Voltage might be changed by using another fixed resistor.
The Power Transistors are made by Sanken : 2SA1695/2SC4468.
The final Reservoir Caps are 2 Siemens AL-ELKO 17,000uF 75V.
OK, I received the caps yesterday. They are pretty heavy and bulky.
I focused my attention on the Amplifier CD Player Input.
2 Ceramic caps, 6 resistors, 2 electrolytics and one OPAMP (NJM2068).
The NJM is in SIL Package. Some Browndogs adaptors will fix this.
I am interested in changing this OPAMP.
I have the following at hand: OPA132, OPA2132, THS4032.
The CD Player is equipped with LT1361 which has a pretty high slew rate.
The CDP DC offset is low, 2-3mV, while the amplifier offset is 15mV (peak)
Here is the input PCB : http://www.uploadgeek.com/uploads456/0/P3106818.JPG
I just bought 5 SDT12S60 Rectifiers.
http://www.datasheetcatalog.org/datasheet/infineon/1-SDT12S60.pdf
The price was very good: 14 Euros ship. incl. to Romania.
- Yamaha AX-390
