i'm working on an xtant x604 (later version of the 604x, same board i believe) the 2 rear channels have high DC offset. 1.4 volts on the left and .5 volts on the right. the right still sounds fine to me but the left sounds a bit distorted and lower volume than the right.
here is some history on this amp: this guy brings it to me from his dessert rat truck and says he just wants it cleaned and that it was working fine last time he used it. he said it had beer spilled on it and that it worked after that but he disconnected it and took it out of the truck and it sat for a while. the board was filthy! it has encrusted dessert sand stuck in every crack and crevice and dried up beer spots. i brushed of what i could with a paint brush and then i used acetone on the bad spots. this got most of the mess off but some ares looked bad still so i sprayed contact cleaner in all the pots and cleaned some more. i noticed a broken lead wire from the remote circuit and a small electrolytic cap with a lead broken from the board. i repaired these items and hooked the amp up. big suprise, it actually worked. well it sorta worked. the rear left channel was distorted. i noticed a fried 100 ohm resitor that led to a small smt pnp transitor. i replaced these items and noticed 2 bad 100 ohm resitors in the right channel along with another smt pnp. so i replaced these too. the other bigger transsistors (BF422's and so on) in both channels appear to check ok as well as the other resistors. after this i still got the same sound or therabouts and the DC offset is at 1.5 volts left and .5 volts right. the front channels have nearly no DC offset.
what else should i look for? i see 3 electrolytics in each channel that i think i will replace. the one's in the right rear look to have been changed before because they are different brands and color but same value. i'll change them anyways.
it's amiracle this thing works at all but i think i can get it back to full strength with a little help from you guys.
