XRT28 in mind
The McIntosh XRT28 has 10+10 4" mids and 16 tweeters per side.
In my look-alike/wannabe/cheapo/me-too project I have 8+8 mids and 16 tweeters per side, but in OB.
The drivers are chosen from Zaph project ZBM4: Aura NT1 and MCM-55-1853.
Hopefully, they will not be much stressed in this array.
Woofers are 2x 12"sls in vertical Ripole.
This system is 3 way, managed from a Behringer DCX2496 .
The big question for you, the skilled reader with high eyebrows:
How should the drivers be wired ?
Is "normal" 4 in series and then parallelled in groups of 4 to 8 ohm the way to go--- or do the Bessel-goast appear ?
(I'm worried for this).
Ok, I take lack of replies that wiring of arrays not may be a common case.
I heard that listening distance is approx 8-10 x height of line source.
This may due to reduction of delay between center-to-lower/upper tweeter as listening distance increases ?
Anyway, Bessel or not to Bessel, I can try to reduce the virtual distance in a mechanical way by curving the arrray.
Please (!) arrest me if I'm going totally wrong.
