I recently bought an X150.5 and will be using it with a Parasound JC2 Preamp. The JC2 XLR pin configuration is 1-Grnd, 2-(+) and 3-(-). I tried to find the X150.5 pin configuration but had no luck. Can anyone help?
Pin 1 should be Chassis, not ground.I................The JC2 XLR pin configuration is 1-Grnd, 2-(+) and 3-(-). .............
You can test your XLR wiring with the Hummer from Whitlock, or one of his mates.
Thanks, Ill look into That.
