WTB: Small integrated tube head to drive 10 inch Hartke aluminum bass instrument speaker. Replacing original 120 watt (assume this rating NOT conservative) solid state head in 12WXD8X3H inch opening. Will consider taller unit to be mounted inverted. Would like a pair of 6L6's or EL84's or equivalent in power output section, preferably preamp section that can accommodate 1/4 inch jack and passive gain pickups (typical Fender setup). I don't have the skill or time to work on fixer upper, so it should have good capacitors, no hum, safe and grounded electical power, and be properly set up and calibrated. Please contact me by private message. Thanks.
