Jonathon
> Welcome back to diyAudio!
Thank you! . . been a while )courtesy of diyAudio not liking my new gmail address . .)
It’s for a two way active, crossed 250-500 Hz
I didn’t hear anything, so I’ll probably use a 5 * 140 wpc Marantz HT amp I have. The power should be enough for the bass, not sure about the SQ for >250~500 Hz . .
Few plate amps will cross above 150 Hz, and I want to run the CSX 10"s up to c 300 Hz. The newer Reckhorn A-400’s I was told can cross at 300 Hz, but its c $US 260 . .
Cheers
Cheers
