Anyone have some originals they want to part with? I could also use mono boards if available. I just don't trust chinabay parts.
Thanks!
Jeff
Thanks!
Jeff
same here, just in case, shipping should not be the problem.
Also DRV135 and INA134/137.
Will probably never use them.
Max
Max
ok,
I've got two balanced line driver circuit using the DRV134 on dip8 sockets plus two unused DRV134 dip8. I will send those to you for free but will need to check how much to send the small PCB with components on them. If too expensive, I'll just send you the 4 DRV134 in an bubble envelope but the'y be in a protective tube.
Just PM me your address
Do
Do
