WTB: Adire Brahma 15
alternative?
I don't have an Adire Brahma, but I do have an Exodus Tempest-X which is probably one of the few subwoofers as capable as the Brahma. Also has the same XBL^2 tech. Dual 8 ohm coils. Actually quite similar to the Brahma - it was developed later and Dan Wiggins of Adire and Kevin Haskins of Exodus were business associates, and so the relationship makes sense. I'm asking $135 for it.
Here are the T/S specs:
Fs: 18.5 Hz
Le: 0.90mH
Re: 3.65 Ohms (Voice Coils wired in parallel)
Qms: 3.4
Qes: .60
Qts: 0.51
Mms: 200g
Cms: 0.37 mm/N
Vas: 324L
Sd: 791 cm^2
Vd: 4.27L
BL: 11.86
X-max: 27mm
Pmax: 600W
SPL: 87.2 db/1W/1M
Shipping wouldn't be cheap as it's quite heavy and I'm in California...
Best,
Tal
Hi Architect, thanks for the heads-up, but I didn't see anything on Audiocircle, maybe you have a link?
Taloyd, thanks for the offer, but I'm hoping for a mate to the lonesome driver I already have. Do you only have the single driver or multiples?
Cheers, Ralph
