I'm thinking of buying some tech equipment. This Rohde & Schwarz is in Madrid. I have no idea so I ask here. Good, bad idea?
My experience with old test equipment has not been a good one.
Really old equipment is usually way out of calibration and will have problems. I have never been good at repairing these things as they are much more complex than the gear I am testing.
My recommendation is to buy as new as you can possibly buy with as much money as you can.
The good news is, with the Spanish economy pretty much in the tank there should be a lot of test equipment on the market from companies that have gone out of business. It really should be a buyer's market out there.
Lastly, if you are buying this to keep as a museum piece and not using it do do work, then it's another matter.
Check out eBay for Tektronix scopes. You can find some older, but good scopes for a reasonable price.
I bought a Tek 2430A a few years back for about $300 that has served me reasonably well.
New entry level Tek scopes start at about $520 (TBS1000) and are not only calibrated, but come with a warranty.
I also just picked up a Bitscope 310U, which turns your PC into a mixed mode oscilloscope (logic and 2-channel analog).
While it is okay, it doesn't have the advantages of my Tek scope, which has a much better trigger and measurement system compared to the Bitscope.
The tek does not have the logic analyzer, but for working with audio signals my old Tek beats the Bitscope hands down.
On the picture is (I suppose) an VHF network analyzer, that needs also special probes. Its field of usage is also very special: adjustment of RF circuits and filters in the MHz range. R&S gear are built like a tank, but they could still develop intermittent contacts. All in all, it is not useful in audio
- Tubes / Valves
- Would this be a good buy?
