My latest LM3886 Chipamp build took the place of a Manley Stingray in my main setup, the sound is spectacular. I'd like to add a subwoofer output (can't run from the binding posts as the sub is small and doesn't have speaker level inputs). I tried running an output after the volume control (before the signal is amplified) to the sub but that didn't work.
It's looking like this may be an option:
http://www.sunsky-online.com/product/default!view.do?contact=&subject.id=315226
and this for power: Avel Y236103 30VA 15V+15V Toroidal Transformer
and throw both in a box, then send the volume controlled signal to that.
Any thoughts/recommendations? TIA.
