This is a shorted list of tubes I can buy. Useful or not?
e2d - 20$ 8x
c3c - 20$ 4x
c3g - 34$ 20x
c3m - 34$ 10x
807 - RCA - 28$ 8x
AZ1 - 14$ 4x
AZ50 - 16$ 8x
GZ32 Philips - 26$ 4x
6k7 RCA - 25$ 10x
6k6gt RCA - 25$ 10x
5Y3GT RCA - 18$ 12x
Philips Miniwat 6080 - 60$ 4x
12sh1l (russian 12ž1l) 10$ 100x
EC88 (single triode) - 14$ 20x
Thanks!
e2d - 20$ 8x
c3c - 20$ 4x
c3g - 34$ 20x
c3m - 34$ 10x
807 - RCA - 28$ 8x
AZ1 - 14$ 4x
AZ50 - 16$ 8x
6k7 RCA - 25$ 10x
6k6gt RCA - 25$ 10x
5Y3GT RCA - 18$ 12x
Thanks!
The ones I know:
c3m - nice signal pentode with loctal socket
807- 6L6G with top cap, useful and rugged power output tube, 5 pin base
AZ1, AZ50, GZ32 - cool looking old rectifiers- AZ tubes have weird bases though, may be very hard to find
6K7 - metal tube radio pentode, no real audio use
6K6GT - medium power audio pentode, like 6V6. Nice as a driver possibly?
5Y3GT - low ish current rectifier (GZ32 is far superior)
6080 - worse version of the 6AS7G regulator tube. Good if you want to make an OTL amp. not for much else though.
EC88 - single triode- NOT equivalent to 1/2 ecc88 though. Could be a good driver for a 6K6 of 807 though.
The sockets might be hard to get for some of these, especially the loctals and AZ tubes.
Those prices are for the whole lot I take it, otherwise theyre a bit pricey.
barretter said:EC88 has twice the gain of an ECC88 and similar transconductance but is not as linear. Makes a good cathode follower.
Do you have some schematic where it is used?
Cheers
Andrea
SHiFTY said:6080 - worse version of the 6AS7G regulator tube. Good if you want to make an OTL amp. not for much else though.
Or use them to cathode-drive an 807 (or 6L6) that's grounded-grid, SE - You'll be amazed
6080 - 807 (GG) SE Amp
Geek,
Would you mind posting the schematic of that circuit?!
Regards,
Yugovitz
Geek said:
Or use them to cathode-drive an 807 (or 6L6) that's grounded-grid, SE - You'll be amazed![]()
Geek,
Regards,
Yugovitz
Re: 6080 - 807 (GG) SE Amp
Here's the entire R&D thread on it!
http://geek.scorpiorising.ca/cgi-bin/yabb/YaBB.pl?board=projects;action=display;num=1091662757
Yugo said:
Geek,
Regards,
Yugovitz
amperex said:I do not see any real useful tubes- perhaps the 5Y3 rectifiers.
The C3* valves and the 807s are very useful valves.
A pair of 807 into a 6.6K load cal produce 26.5W at 1.8% THD.
A triode strapped C3g has ra of only 2.3K and a µ of 40, and is impressively linear.
If the price is per tube, thats outragous.
Most definitely.
Re: Re: 6080 - 807 (GG) SE Amp
Geek,
thank you very much.Excelent thread!!
Regards,
Yugovitz
Geek,
Regards,
Yugovitz
- Tubes / Valves
- Worth to buy - tubes?
