My son is in need of an amp for his Yamaha keyboard now that he is starting to play in a band. Im unfamiliar with guitar/bass/keyboard rigs other than those used for larger ProSound setups.
Most of the smaller practice type amps Ive looked at are either thrashed (used) or the new ones that are <$200 look pretty cheesy. So is it worth building something on the cheap or just buy a Behringer etc.
What I have on hand is an orphan Eminence 12LTA, a LM1875 and LM3886 amp, and plenty of BB ply. My thoughts were to add a piezo, and mixer/tone circuit ala Elliott Sound.
Universal Preamp/ Mixer (Part 2)
Will I wind up with a better amp than the cheap 8"/10" commercial versions or am I wasting my time.
amt
amt
keyboard
There are lots of posts on diy about the lack of support (schematics) that behringer gives to their equipment. If the guitar player is going to plug in his amp to the keyboard amp and fry the input parts, (a common amateur guitar mistake) then having built it makes it a little easier to recover. (I just repaired a peavy PA amp the apparently was done to - fried input resistors). Keyboards, if they are used for piano synth, need full frequency response, including some sort of a tweeter in addition to your 12" or 8" woofer. That means chip amp plus crossover. I just realized your reference to piezo is not an alarm or a microphone or a gas lighter, but a piezo tweeter.
For a simpler, cheaper input board, look at the tonepad.com mini amplifier board, at $13 including shipping. Add power supply bypass caps, he doesn't understand them. You don't have to use 4558 op amps, I have direct replaced them with 33078's in a disco mixer with much less hiss. Peavey uses JRC4560's in the late 90's. For power supply I am going through the grocery cart of wall-chargers at the charity resale shop, at $1 each they are the cheapest transformers around. No reason you can't mount them inside the box. Use real fuses or a breaker for real gig hardening (no lost fuse caps in the instrument truck).
Another option is an orphan used full frequency speaker, like a Peavey PR15 or SP2, (really nice tweeter) and build the amplifier inside the box. By orphan, buy a pair one of which is blown up. That way the speaker engineering (which requires a lot of testing, in my opinion) is already done.
I bought a cheap keyboard amplifier and was dissatisfied with the sound. But the amplifier, 30 Watts, seemed okay so I pulled it out and installed it into a bass speaker. I moved the tweeter and crossover as well and now have a more than adequate keyboard amplifier. My keyboard is a Casio PX-100 which is about as good as I could want, given that none of them sounds all that great. Especially since I also own a grand piano.
If you want a project to build, then fine. But if your main intent is to give the kid an amplifier for his keys, then really, look at the used pro gear market.
Don;t be distracted by the appearance. Just because the tolex is ripped and scuffed or a metal corner is missing or candle wax is dropped over the top, doesn;t mean the amp doesn't work and sound just fine. And for that matter, something that looks like new can be really screwed up inside.
Listen to any potential candidates. take a CD player with an appropriate cord, and play the music through the thing for a listen.
An old Peavey KB100 is a solid basic keyboard amp, and can be found inexpensively.
Um... plugging a guitar into a keyboard amp won;t hurt it in the slightest. keyboards put out a line level signal, far hotter than anything coming from a guitar. A guitar can't burn up a resistor. Your guitar pickups just can;t generate the power for that. If resistors were burnt up in an input circuit, then either someone plugged the output of a power amp in there, or some piece of gear that was not well grounded and AC on the chassis.
In decades of repairing various guitar and PA amps etc. I've never seen one damaged in that way?, or heard of one before. Although depending on the input design I suspose it is possible?.
In many respects a keyboard amp is pretty easy, it's just a linear high quality amp, a PA is ideal for it. A decent little HiFi amp would do it as well, as long as you don't push it too hard. It's certainly essential though to use a tweeter as well as a bass unit to get a decent sound.
I happen to have a nice little 60W Fender keyboard amp, which I got for free
Take him to the shop, let him try a number of amps, buy him the one he wants. The one he wants, even if you have to buy a secondhand one elsewhere for budgetary reasons. If there's a financial constraint he'll understand that. An amp that's a bit battered is not the end of the world. Don't rush him into making a choice. He won't understand that. Don't just buy the most expensive one because you're flush.
You should preferably buy one with a 12" speaker. Don't build or adapt an existing amp, these can be fine or even preferable for a mature player, but a young person needs something with street cred.
w
w
Like the street credit thought. Kids are vicious.
My points are 1. Piano one of the hardest sounds to do right. He may never use it, but a good sounding speaker on piano is good for most everything else. I've had 4 generations of speakers over the years, the latest are the best yet on piano. Give your kid the opportunity to hear the difference in fidelity on a good piano CD for test. The speakers I mentioned are about $200 used, the KB100 is about the same. Right on about at least 12" woofer, but I like a 15" woofer better on deep piano bass. Besides, the other kids may respect a 15" woofer more. Building a good amp into a speaker is doable, building a good sounding speaker for piano is hard to do.
2. Amateur bands have a lot of 1/4" phone plugs, for various purposes from guitar pickup, to mikes with phantom power, to keyboard output, to PA amp output. Getting them crossed is part of band learning, and can fry things. Pro bands use speakon connectors for the high power outputs, but I've never seen a used amp I could afford in this county with speakons. Pro bands also use XLR connectors for the phantom power things. Spending more money for more reliability is something kids have to learn.
3. If you can fix things, behringer doens't give out schematics. Lots of other brands do. A toasted 1/8 watt resistor looks just like a toasted ceramic capacitor these days, schematics are nice to have.
..........but a young person needs something with street cred.
w
I know exactly what you mean, being 16 myself. I have a heavily modified guitar amplifier from the late '70s. I still find myself looking at Marshall gear, amongst others, for the street cred. Mine sounds nicer (than the one I'd buy), but no-one's heard of it (that said, plenty have heard the amp itself
Apply that here, and you're absolutely right, get one that has a decent balance between sound and street cred.
Apart from that, make sure it holds the sound together when turned up. Nothing worse than liking the sound at low levels, then it all falls apart when you try to keep up with the drummer. I wonder if 1x12" is really enough to hit the lower notes on a keyboard when the drummer's going for it... Perhaps 2x12 is in order?
Chris
Guys, heres the deal. My son just turned 10. He doesnt need street cred since hes not allowed on the street
What he needs/I want is a small lightweight amp he can actually carry and that will produce enough sound to equal the other kids' amps. They all use small Fenders, Rolands or Peaveys. Ive got plenty of pro stuff available to me for gigs (someday) but right now compact starter is whats up.
He is also quite happy building something since he gets to participate and has been schooled in the zen of diy audio.
My only concern is the quality of the amps. Ive seen lots of larger amps used but they are just too big. Lots of little guitar amps though.
Ive got the Eminence 12lta mounted in a sealed/ported box and will fire it up with a chipamp and see how we are doing. My thoughts now are build it as a powered speaker and later, add a mixer like this Mackie.
Buy Mackie 402-VLZ3 Compact Audio Mixer | Unpowered Mixers | Musician's Friend
Boils down to this: Is a nice chipamp, the 12lta and the Mackie a better collection of parts than a $150 8" commercial amp?
Custom Cabinets
Custom Cabinets
If he has an 88 note keyboard, there is need for good low end response. An 8" speaker probably wouldn't have much bass in a small box.
A single chip amplifier is a good idea; you can get a 30 W IC for a few bucks. The hardest part is the speaker and box. You don't need much preamplifier, as a keyboard has significant output. Tone controls probably not necessary - mine always set to the middle.
30W will make some noise. a 12" woofer with enough power and excursion diy has better bass than any 8". If he helps build it he will always be proud, even if he upgrades later. Best of luck. I'm using a $15 disco mixer as my home system hub, so they have some possibilities although I've changed op amps and caps for better sound. They are light enough.
I helped my Dad wire a den when I was 11, using a little Sears "how to wire your room" booklet. I tested out of Electricity 1 at 50 when retraining at the community college, and went right into electricity 2 (factory wiring) based on my work at age 11. Kids that diy are the future of manufacturing in this country.
Buy him a small Fender, Roland or Peavey.
No. You can't build a decent instrument amplifier as cheap as you can buy one and it will never look the same. Do you make his clothes?
I don't understand why you can't just ask him, and take aboard what he says.
w
Yes it is. Having said that, its easier to tote the 8" commercial amp. I'm not sure why you really need the Mackie though as the output from a keyboard is line level. I agree he doesn't need much "street cred" yet. I also agree to talk it over with him; I think as long as he understands you're trying to get a reasonable rig for him he'll be fine.
Well I tested the 12lta/lm3875 in a sealed 1.5cf box and it far outperforms the little Crate 8" he borrows or the budget Fender/Behringer I listened to at the big box music store. None have any bass and are pretty flimsy.
The mixer just an idea. I though that its an easy way to either add a mic or another keyboard to the amp we are building or to use with a bigger pro sound setup in the future.
As to what he wants or desires, he has gotten used to custom everything and is aware that "off-the-shelf " mass market is just that. He is also an artist and quite creative and is usually drawn to the unique and non-mainstream approach of things. He has also been schooled in smart consumerism, value, quality and the evil of planned obsolescence and mediocre manufacturing.
So, we now have some beautiful clear pine and have some amp parts (grill cloth and hardware) on order. I hope to get the cabinet going next week and build up the amplifier assembly as well.
amt
amt
Having a spare input (even if it's connected to the same pre-amp etc) can be very handy. I know it's useful in band situations when someone fails to bring theirs, or the PA packs up and you need a wide range for the vocals. You can change the volume on the keyboard too, to get them in line.
Sounds like DIY will once again triumph.
I know exactly what you mean, being 16 myself. I have a heavily modified guitar amplifier from the late '70s. I still find myself looking at Marshall gear, amongst others, for the street cred. Mine sounds nicer (than the one I'd buy), but no-one's heard of it (that said, plenty have heard the amp itself).
Chris
There's no point competing with a drummer going full pelt: a single 12" would be fine powered by a valve (triode or tetrode) because the even-order harmonics would allow the fundamentals to be recognised by the frequency complex.
A push-pull typology would help for bass and transient reproduction coupled with a (tough..) full-range speaker?
Tubes are nice, but heavy. The child in question is 10. When I was 10, I weighed 60 lb and could lift about 20 lb. So chip amps are ideal even if the sound is not ideal. When he grows, the next system can be . . .There's no point competing with a drummer going full pelt: a single 12" would be fine powered by a valve (triode or tetrode) because the even-order harmonics would allow the fundamentals to be recognised by the frequency complex.
Fair point! Tubes aren't the most safe thing to play with either
- Live Sound
- Instruments and Amps
- Worth building a keyboard amp?
