Selling a single midbass horn together with one Oberton 15NMB600 driver. Developed together with Bjørn Kolbrek (PhD in horn theory and author of "High Quality Horn Loudspeaker Systems: History, Theory and Design").
Measures very even and needs little EQ, and has a constant directivity of approximately 80x50° between 200 Hz and 1500 Hz.
The horn also avoids the floor bounce and measures therefore amazingly flat in the room.
A few pictures:
Dimensions:
Width: Max 122 cm
Height: Max 89 cm
Length with rear chamber: 120 cm
Rear chamber is built with a sandwich of two layers of birch plywood (2x 10mm or 12mm, can't remember exactly) with viscoelastic glue between and the horn with 21mm birch plywood. The rear chamber has a 2-pole speakon connector.
It's possible to buy a second midbass as well. However, the appearance will be different than this one and price will be higher. Or perhaps you can use this a center speaker.
Take note that shipment from Norway to the USA can be very high. Shipping to Europe is considerably less. Will need some time to pack.
Measurements here: https://www.soundlyvisual.com/index.php?threads/vera-audio-midbass-horn.35/
Asking price: 13000 NOK (approximately 1129 euro or $1206 plus freight cost. Or you can give a bid.
Contact: info@lydogakustikk.no
A few pictures:
Dimensions:
Width: Max 122 cm
Height: Max 89 cm
