WMTMW, the final overkill?
Hi again !
It's been couple of years since I got my WWMTM Beethoven style open baffles running. Didn't actually finish them at any point and now it's time to move on.
First maybe I should mension few points why change a working concept. First WWMTM dipole was and still is a compromisse. Compromisse between WAF (where it still didn't exactly shine), difficult acoustic conditions and overall performance. While WAF is now gone (literally) I can do much more dramatical solutions as long as I'm pleased with it myself. Second mather is the overall sound. I like the dipoles open presentation but I don't think it's quite the thing for me. Then there is the kick and slam where open baffles just can't give the beating I'm looking for.
Basically this planned concept makes compromisse between room acoustics and raw performance. Therefore (and also while roomdecor is now only in my hands) I can and will unleash some acoustic treatment for my livingroom. Basically turning it more like a music / movies space while compromising it's "livingroom" properties. But since it's also a livingroom I'm not planning to paint it all black or anything as dramatical.
So here we are.
Personally I'd need some opinions and suggestions on two things. First the overall structure and design of the speaker and secondly how I acoustically connect it to my room (basically acoustic treatment questions).
First few things about my room. It's 5,2 deep, 2,6m high and 3,7m wide (approx 17' x 8' x 12'). Front wall is almost completely covered by window and the door to balcony. About 40cm wide pieces of wall a on each side before corners. Sidewalls a plain and made of concrete. Propably the biggest problem and acoustical challenge. Rear wall is thin to bathroom and 1/3rd of it is a open doorway to rest of the apartment. Present dipoles are positioned approx 0,5-0,6m (2ft) from sidewalls and 1,5m (5ft) from the front. Listening position is also about 1,5 (5ft) of the rear wall.
Originally I run few different approaches through my mind. One was or actually still is (as a backup) a standard closed cabinet MTM using my dipole midrange drivers Seas W18E (older model) in a Dynaudio Confidence C2 style slim cabinet. Naturally this doesn't give the slam I ask and they need a subwoofer system to work with. For that duty I thought of multisubwoofer setup. A bit like described years ago in Harman multisub paper. Naturally 80-200Hz area is weaker that with full WMTMW setup along with vertical directivity and of cource less manly looks.
I know most people would just listen their music though some high quality 2-ways but those just aren't for me.
I also got few encouraging experiences from Dunlavy owners in similar acoustic environment (SC IV and SC IV/a which is very similar to this). So. Full scale (compared to room size) 3-way WMTMW it is. I already have two woofer cabinets under construction and I'll measure them in the room so I can deside is it "go" or not. How WMTMW W-W section behaves, how can I position them and so on.
Driver selection is pretty similar to my dipoles. They have Scan Speak 25W/8565-01 woofers, two on each side, with twin W18E Seas units and I presently use Genelec 8050A tweeter above 1800Hz (4th order crossover). Also thought to experiment Dynaudio T330D in this setup.
Personally I like Dynaudio Evidence Master looks and I've heard the speaker couple of times. Modular construction is a must in this one. Simply too large and too heavy to move around in one peace. Two woofercabinets sandwiching mid-tweeter section.
Single 25W needs +65 litres sealed space to have <0,7 Qtc. So I started out of 70 litres for each driver. This makes top and bottom cabinets rather large and using similar size midrange cabinet it makes midrange cabinet way too large for my midranges. Almost 60 litres for two W18E that makes Qtc around 0,5. I don't think there is that much harm from it but should I really go for it or perhaps cut it to 35-40 litres and use the extra space for even heavier bracing and damping? What kind of construction do you recommend? I've seen different diffusor type cabinet internals, bracing solutions etc but which one is most recommendable? Range is about 200-2000Hz.
As for the room I thought to place some bass damping to front corners (40x40 triangle shape fit), catch 1st sidewall reflections to Ecophon Master Alpha or perhaps use QRD or even skyline diffusor there. Then have some Master Alpha on the ceiling (propably with some air between Alpha and actual ceiling).
Well. First impressions? Questions? Suggestions? Complaints? 🙂
Michael,
Which thread do you refer?
Brett,
Those indeed are intresting designs. I've familiar with Stig Eriks previous models but this seems to be at least bigger and probably better as well. Acoustic solutions look very similar to my thoughts as well but I can't use as heavy treatment to front sector that Stig Erik has done. I have windows in that direction and don't care to block them.
Stig Eriks sand filled midrange cabinet is very intresting. I think I'll have to mail him and ask more details how cabinet is build, what shape interwalls and bracings it's using and so on. I think basically a tapering pyramid could be pretty ideal if it has enough sealed litres in it. That way there can't be any standing waves between walls at any frequency and the whole space can be filled with damping material. But like with Stig Eriks design filling rest of the space with sand make them extremely heavy.
Brett,
Sand is wonderful for damping resonance. There are some drawings on one of the old pages here
I guess they are but they don't kill standing waves and other problems that for example parallel walls cause. I think cabinet should be well braced, cabinet parts forming non-parallel surfaces and then have proper resonance damping.
Sand is good also because you can add it after you've positioned your speakers and just finish the installation by filling up. Sand makes it very heavy and difficult to move and carry.
I never said it did. I linked it to show you the way Stig Erik did it in a precious build. I understand there is a difference between panel resonance and the acoustic modes of an enclosed space.
I am the poster boy for heavy bracing, mainly using a variant of the B&W matrix.
My current builds are way too heavy anyway so I'm not adding sand, but once built and positioned, they generally don't move, so it's not an issue unless you're an obsessive tweaker.
Sorry, I didn't mean to accuse you of anything.
Stig Eriks speakers seem intresting but they make me wonder couple of things. First there are pretty large areas where there is no bracing between inner cabinet and outer cabinet. Sure there is sand but sand doesn't grip cabinet parts together in any way. It actually push them apart by its weight. Second thing is the filling itself. It's known that sand compresses into smaller space in time while small grains find their place. Therefore I'd expect some space below ceiling surfaces which leave it open for resonance while 19mm MDF isn't exactly connected to sand.
Two ideas. First I think the sand containers should be something like a funnel or at least shaped enough like a funnel. This way sand will find it's place and fill containers all the way. Maybe containers could have caps at the top where you can check and even add more sand if needed. Secondly cabinets overall construction should be taken care of. In this mather I think there are few even better solutions than sand. Bitumen or even lead-bitumen can be used and these materials also attach cabinetparts together.
SET doesn't strike me as silly enough to have left out sufficient bracing to stop those issues. My guess would be the drawings are incomplete, either becasue a version of these is made commercially and because it's a personal/DIY site he might not have been bothered - the general principle shows.
Agree with this. The last set of stands I made had an opening the size of the vertical shaft for this reason; simply remove the speaker and top up after sone time, and to make it easier to pour out to move house. I don't think a small air gap is going to be critical though.
My new TT bases are being filled with sand (garnet).
I started thinking. Is 25W/8565-01 the best option for this sort of solution?
I know it's still a very good driver but still it puts me thinking of different options. Naturally any other choice puts my Scans on sale but that's also one option.
First thought that bounced into my mind was fitting 18" PA woofers into play. Similar setup that Stig Erik used in his speakers. But that make cabinets way too wide for W18 mids and I don't want to go for Stig Eriks solution of cutted frontplate. I know using W18 in a 3-way is a compromisse, just like Stig Erik mensioned in his report, but I don't intend to go further from full scale 3-ways.
But what about 15" PA woofers. For example L15P400 RCF:
RCF - L15P400
Rugged design, good +-8mm linear excursion, good efficiency and clean responsegraph. Large cones, much less excursion needs compared to twin 10" version. Sticks into 400mm wide cabinet and also fits into compact closed cabinet. Little over 22 litres for Qtc 0,7.
I also checked couple Dunlavy designs width to depth ratio. With ratio of 1:1,625 (650mm / 400mm) my design would still be between SC-IV/a (1:1,5) and the big SC-VI (1:1,8). I don't like square shape cabinets myself..
What do you consider being the best way to cross 3-way WMTMW?
I know 1st order designs like Dunlavy get a lot of praise but it's a clear compromisse when it comes to driver selection, distorsion and other things. Vertical directivity also isn't that great with 1st order crossover.
I remember some Wilsons use 2nd order MTM on the top (Grand SLAMM?), big JmLabs have 4th order as well as Odin, Thor and many other traditional MTM speaker(kit)s.
Vertical directivity can be a problem. Switching from M-M section to single T section changes overall balance quite a lot. In some cases this makes rather critical midrange from 500Hz up to 1500-2000Hz sound a little thin causing some closed down effect from overally open presentation.
W-W section shouldn't be a problem since driver spacing compared to crossover frequency can be matched. With 300mm M-M distance crossover frequency would have to be under 1000Hz that the system would handle like a true pointsource and not to have vertical lobing.
And by the way what do you think of Fountek NeoPro 5i ribbon tweeter? I found some "ribbon low cross" type threads but not that much subjective or even bettern objective information is that unit really good.
I know RAAL ribbons and their foam vertical fix which is possible to use with Fountek units as well. Rather large unit, recommended xover 1500Hz 4th order, +100W power rating, lots of manufacturers praise. Really worth the words and what kind of match would it make with my W18E Excels? I'd like to use as low crossoverpoint as possible since W18 has its nasty 3rd harmonic rise around 1700Hz.
Hi Jussi,
Good to see you building again.
The potential problem you have identified with the differing directivity of driver pairs vs a point source dome tweeter is the reason I switched to a ribbon tweeter in my last (vertically) symmetrical speaker.
Ribbons seem to be a better match for the vertical polar pattern of MTM type speakers. For your application, I'd seriously consider a large ribbon. Better yet, a ribbon in a WG would provide lower distortion around crossover and reduce sidewall reflections, or you could use a dome/compression driver in an asymmetric WG.
Jussi
I think the Beyma TPL-150 is a better choice than the Raal, atleast if your goal is as low crossover as possible in an MTM-configuration. The Beyma can be crossed over as low as 1100-1200 Hz
Other tweeters could be the Stagecompany-ribbon, but I do not know whether e.g. Partsexpress still have them in stock.
Brg Gisle
I started considering this Ciare woofer for the W-W section:
http://oem.ciare.com/en/296/365/prodotti.php
Good efficiency, decent +-8mm linear excusion (present 25W Scans have +-6,5mm), small cabinet requirements.. Actually 80 liters sealed cabinet give below 0,5 Qtc. Very low group delay, under 7,5ms with 200-250Hz 4th order lowpass at 20Hz. Large 830cm2 cone compared to 330cm2 that 25W provides. 80 liters cabinet space would also allow vented setup. 400mm long 100mm tube gives rather nice 24Hz tuning and +3dB more efficiency 25-40Hz. But I don't know is it really worth it. Groupdelay increases, I can't eq response go to subsonics and even closed setup has plenty of output in my modest size room.
What do you think?
Actually you often hear the comparison that PA stuff don't play deep bass. Putting 25W 65-70 liters closed response in same graph with Ciare there isn't that much difference in deep bass area. Efficiency difference at 20Hz is only about 0,5dB which is rather insignificant. Above 60-80Hz Ciare rocks on with its efficiency.
Paul,
Which ribbon did you use in your MTM?
Fountek 5i looks promissing but there isn't that much proper information of it. With similar cash I can buy many HQ drivers so I'd need more information before making such investment.
WG is also in my buildlist. With ribbon it's also relatively simple to prototype and construct.
Didakt,
Looks pretty good. It isn't exactly a ribbon but similar structure. I asked more information from local Beyma distributor.
I think Stig Erik is using the Beyma AMT with Excels in his project and seems pleased with it.
Yep. Let see what Finland local distributor has to say about them. Or is that model out of production?
What do you think:
WMTMW with large woofers (propably 15" PA stuff), W18E Excels and a proper tweeter (Fountek ribbon, Beyma AMT, perhaps few dome models could do..) crossed 200-250Hz and 1500-1800Hz. Closed cabinets.
Or:
WWMT with my present 25W Scan Speaks in closed cabinet, something like a C2-79 Accuton for mid and a nice little tweeter (OW1, XT19) on the top. Crossed 250-300Hz and 3-4kHz. Maybe passive approach.
Here few ups and downs:
WMTMW:
+ Manly looks, simply massive
+ Adequate raw performance (SPL, low distorsion, dynamics, efficiency)
+ Modular construction (a must with such mass)
- Needs a pile of new components (that I don't presently have)
- A total overkill?
WWMT:
+ More open imaging (is it just an illusion that MT is more open than MTM top?)
+ Possibility of passive crossover
- Complicated to build
- 1-part construction
Basically I see this like a brutal SPL monster with razorsharp details, killer dynamics and basically like a "monitor" compared to a music lovers sweet dream. Is there even a "better choice" here? Are they just different?
Two very different approaches!
I have always liked the stable soundstage of the WMTMW configuration so that is what I would choose for myself. As I remember, your room has extremely hard (concrete?) surfaces so WMTMW should have more friendly room interaction. Distortion should be lower with higher dynamic capability.
Woofer choice would depend on how they model in-box, and box-in-room. I favor low extension/low excursion/low distortion. Are you thinking pro version must be active XO because of sensitivity? How about pro woofers in series with mids paralleled for a better sensitivity match?
Modular approach has one nice advantage...you can always change one section at a time if you are not satisfied with, just for example, HF section.
Actually Stradivarius style cabinet isn't that bad in room. Check out for example Stereophile measurements of the original design. Wide baffle really counts when it comes to directivity.
As for dynamics, efficiency, low distorsion, extension and so on I agree but where is the limit? I simulated twin 15" pro woofers in sealed cabinets to my room and got pretty impressive +110dB linear excursion limits at 20Hz. That's loud. Naturally this means very small excursions at any actual listening level. For example 85dB 20Hz tone would cause under +-1mm movement for the cones. Naturally headroom would be impressive and there just isn't a reason for separated subwoofer even with movies.
WMTMW with 25W Scans would make it a lot slimmer. Maybe about 10cm. Of cource this cuts some of the bass headroom and propably some slam as well since cone area is less than half. Sure the WWMT and WMTMW with identical sealed 25W solution has similar limits to their low end extension and capabilities. 15"s run in different league but also require investments.
Where is the limit? I believe in the saying "headroom is your friend" so, from my perspective, you would be well within limits with the 15".
The Octagon
