Well, this is the situation: i need a 18-0-18v 400 (at least) VA transformer for my dual '96 JLH. This is not a "standart" voltage, so it has to be custom built. After some averiaguations, it's arround $40-$50 for an E-I. Double that for a toroidal..
Now, my dad asked "100 bucks? Why don't you just build your own? We made our own transformers all the time in University"... good question 🙄 The maths behind the turns are not complicated, but, in practice, has anyone tried this out? I'd like a toroidal; it's a bit messy to work with, but since we're talking a few hundred turns i can live with that. E-I is out of the question; eddy currents are not easy to be made small enough on homemade transformers... or not?
So... Comments? Links? Prices? Thanks in advice!
So get your Dad to wind them...
Okay, maybe not.
There have been several threads on this. Do a search and see if you can scratch up some basic info. I think there were links to sites with info. However, I think your basic problem is going to be finding cores, whether EI or toroid. Once upon a time, they were more available...nowadays, they're scarce.
One option is to take a transformer of known VA, strip the secondary (leaving the primary) and rewind an entirely new secondary. Keep a count of the turns you remove so as to be able to calculate the turns you'll need to get the right voltage. The current rating, of course, will depend on the gauge of the wire you use. I've done this. It works well, but is tedious.
Another possibility is to take surplus transformers that have a slightly higher voltage (say, 20V) and simply remove a couple of turns.
Grey
Okay, maybe not.
Grey
GRollins said:So get your Dad to wind them...
Okay, maybe not.
He'd be happy to supply me with literature on the subject, but i beleive that's about it 😀
Today i'll storm the local transformer winding shops and see what i can find... the idea on the old transformer is good, specially if the VA ratings are met. I'll see what i come up with... my idea was to spend $20-30 for a ring core and the wire.
So, besides doing the maths well, picking a suitable wire & core, keep the turns tidy and covering as much as the core as posible, is there anything i should be aware of?
Local transformer winding shops?
Wish I had a few of those.
Nah, sounds like you've pretty much got it covered. Just take it slowly and do a good, clean job. You'll be fine.
Grey
Grey
speaking of DIY transformer winding...I was even tempted to get a RUFF toroid winder but seems that their prices are quite steep 🙁
I've just rewound a 500VA toroid. This was
originally 25-0-25V, but I wanted 35-0-35V plus a
low-current 45-0-45V winding.
It's a perfectly straightforward job, but it does
take forever to get twenty metres of 1.6mm wire
off the core and then wind nearly thirty metres
back on (and then 35 metres of the thinner stuff
on top). It's also a real pain to get the turns
tight and tidy, especially with the thicker wire.
cp642, what does the Ruff tool do?
Alex
Alex
Alex...the Ruff tool is a toroid winder for more info check out www.ruff-inc.com....... a good investment if you in some serious DIY stuff and the cash to spare 🙁
Lisandro,
It´s not so difficult to rewind an old transformer, specially if you find one with no veneer in the bobin.
If you make a good mounting job, there is no problem about leakage or eddy current.
hold on......
if you were honestly concerned about $100 being the price for an 18-0-18 400VA toroid....they're not that expensive.
Plitron (to name one company...) make very good toroids that are $53 for all their 400VA toroids....This is pretty reasonable...
Plitron's cool. I like 'em. Good, beefy transformers.
Think ahead, though. They've got a long lead time.
Grey
Grey
GRollins said:Local transformer winding shops?
Well... yes. I just picked up the phonebook and got several adresses and emails. You give them the ratings, they make it: from small signal transformers to mounstrous industriall stuff. Scary 😀
Anyway, best quotes i had were $40 for an E-I and $80 for toroidal. Still had no luck finding cores and separate parts... BUT, i do have an old bulky E-I with the secondary shorted. I'll take some measurments too see if the core can take the VA rating and perhaps i'll work with that one.
Again, thanks a lot for the feedback!
jduncan said:Plitron (to name one company...) make very good toroids that are $53 for all their 400VA toroids....This is pretty reasonable...
Piltron DOES make good looking toroids, and i'm sure they're excellent quality. But i'm outside the US, and with S+H and taxes, i'd reach the $80-$100 barrier anyway.
Last time I ordered from Plintron I bought a custom 750 VA dual 45V secondaries with integra thermal switch (I hate smoke). Delivered, this was around $75 US. Plintron is in Canada by the way, not USA.
The 400 VA transformers are a lot cheaper than the 750 VA.
Phil
Phil
help
Hi friends,
I had a toroidal transformer of 18-0-18 and i rewinded it to 25-0-25 successfully.Now i wanna rewind a 0-55/8Ampere transformer to get 30-0-30. The secondary of the transformer has got two wires running in parallel instead of a single wire. What should i do to get 30-0-30 .
hope someone would help me,
Aman
Hi friends,
Aman
Toroids
There is a place that sells reasonably priced toroids, all kinds
of voltages and VAs.
http://www.par-metal.com
They also sell on e-bay, just search under toroid transformers.
I just bought a 750Va, 45+45 v, for $50.
If you want a toroid that is not a "standard" voltage out, simply buy one that is rated for the next lower, "standard", voltage out and add a few turns of wire to the secondary. There's no point in unwinding what's already there when all you have to do is add a few more turns.
The same technique can be used to lower the voltage of an existing transformer- just wind the extra turns in the opposite direction. The voltage across the "new" winding will subtract from the original winding voltage. Use wire of a gauge that is appropriate for the output current.
If you need an extra winding to get some power for some other circuits, or a cooling fan, or whatever, just add another winding yourself. Low voltage windings don't require much wire or time. Don't know the turns/volt ratio of the transformer? Wind 10 turns around the core, measure the voltage, and divide by 10.
It's easy, cheap (because you can use a surplus transformer), and it works. What more could you ask for?
When you buy surplus toroids, be sure the center is not potted!
I_F
I_F
OK, we have a general idea of what it would take to wind a Toroid, but what about details..............
*If you do get a toroid core, what gauge would be recommended for primary and secondary for 400VA, or 800VA
Also, where could you get empty, large toroid cores and be sure they can be wound for 60hz 120V operation? Any websites sell empty toroids?
- Design & Build
- Parts
- Wiring your own... (mumble)... transformers
