Well, I bumped up R10 & R21 a little, and that fixed the problem of running out of pot adjustment on the 5842's.
The amp is presently functioning, although my B- is around -300V. I smoked R5 once already, so I replaced it and swapped out the MOSFETS, replacing the 2SK3563 with the 900V rated parts (2SK3564 IIRC).
I replaced R5 with a 3K R in an attempt to reduce the B- voltage, but then I ran out of pot adjustment on the 300B's......so I put a 270R back in for R5.
My transformer is a Hammond 273BX 350-0-350 and runs a bit high. I've added another RC stage in the PS; instead of just a choke in place of R4 I put the choke, then another RC stage. My B+ is about 400V with a 5AR4 when running about 65ma through the 300B's. But the excessive B+ is making the B- very -ve.
I've been calculating the various expected voltages down the bias circuit to ground, but I don't really know how much current is flowing through the MOSFETs to determine whats good and whats bad.
I just placed an order with Edcor today for a XPWR131, so the project goes on hold...
so....a few questions.....
What are the symptoms of blown MOSFETs?
Whats a reasonable B- voltage with the Edcor 330-0-330 transformer? -300V seems like a long way from -150V....I'm assuming the -150 is with a transformer suitable for 45 outputs.
