There is a wiring diagram to wire a Tubelab SPP in UL configuration, but I can't find one for wiring in triode mode.
I'm wiring Edcor CXPP25-8K OPTs with 4, 8, and 16 ohm taps on the secondary side of the transformer.
Use with jumpers in FB positions, all other wires like UL configuration?
Since the goal is just to link the screen to the anode, and the principle is the same as for the SSE, and both boards share the same connectivity, then the wiring diagrams for the SSE should be a good starting point ...
SSE Wiring diagrams
SSE Wiring diagrams
- More Vendors...
- Tubelab
- Wiring the OPT to Tubelab SPP
