WinISD Pro program not closing on Windows 7
Hi Members,
Been away from system design for quite some time and finally getting back into learning again. Not sure if this is the place to ask such a question thus please point me to the correct forum if sent in error.
I have installed WinISD Pro on Windows 7. It seems to run ok except when I try to exit the program an error message pops up that says, "Access violation at 00000000. Read of address 00000000." -end-
Have no idea what this is referring to and have to exit the program via windows utility called "Windows Task Manager" > End Program.
Any ideas on how to fix this error message would be appreciated. Thank you kindly.
I'm running Windows 7 Home Premium 64bit and this is what I did to eliminate the problem.
1) Right click on the shortcut and select "Properties".
2) Select the "Compatibility" tab.
3) Select the check-box for "Run this program in compatibility mode for:".
4) In the dropdown, select "Windows 98 / Windows Me".
5) Click "Apply" then "OK".
XP mode didn't work for me for some reason so I did this and it worked.
WinISD
Hi Members,
WinISD work well in windows 7! You must running it as "Administrator" and in compatility mode as win98, It's not working because it's an old Visual Basic application. You should disable visual theme too.
