I use Microsoft update for XP sp2 every week or so.
Tonight it failed to install all 11 high priority updates.
error code 0x80200010
The help offered by MS is completely confusing.
Help.
signing off tonight, back tomorrow morning.
Help.
Hi Andrew,
When you connect to the Windows Update Web-Site, are you using Mozilla Firefox or IE? Maybe something has changed with Microsoft (something downloaded last update session) and it has to be through IE now. They seem to be tightening the belt with unauthorized software pirating and other browsers impede their checking.
Or NOT!
Clean everything in your computer before trying again. Run Ad-Aware, Spybot and whatever Virus program you have and also clean out IE (Delete Browsing History) under tools. Delete everything (temporary files, cookies, browsing history, and form data) except for Passwords unless you don't have any stored then delete everything. There will be a few things to re-do like websites on your drop down browser, etc., but you also get rid of a lot of garbage.
And stop visiting those NASTY sites.... you know.... other DIY sites! LOL
Regards//Keith
Or NOT!
Regards//Keith
KP11520 said:Maybe something has changed with Microsoft (something downloaded last update session) and it has to be through IE now.
I thought windows update only ever officially worked through IE. For other browsers you need to use something like this site....
http://windowsupdate.62nds.com/
I've never had an update fail in the ~7 years I've used XP. I use IE to update so w/e.
EDIT: BTW Andrew, windows ony releases updates on the first Tuesday of every month (unless there is a severe security threat), so there is really no need to update every week.
Hi Andrew,
error 0x80200010 relates to the network link being broken. You either tripped over your ethernet cable, have got a security problem, or your security software might be in your way (which should be deactivated during the course of the update).
Additionally, cleaning some directories in "%Windir%\SoftwareDistribution\" might help overcome a broken update software on your machine. In "Download" there might be residuals of a failed update attempt while "SelfUpdate" might contain a broken update engine.
Additionally, the file "ReportingEvents.log" might contain clues about what went wrong.
But before you go through all this hassle, just retry once more in case it was their fault. 😉
Cheers.
Cheers.
Give me some time to work through those options.
I'll get back.
ps,
Firefox allowed me to update previously.
But my trial of Mcshield expired and I uninstalled it.
I'll get back.
ps,
Firefox works with "Windows Update", but not with "Microsoft Update".
A previous update session might have installed the "Microsoft Update" program, which is a so called "ActiveX" control and requires "Internet Explorer".
Cheers.
Cheers.
A few weeks back I suffered a major PC failure (the power supply fried and took out the motherboard). Once I got the replacement hardware booted up, I could not boot from the HD. Repairing Windows XP from the CD got me back up and running, with no apparent loss of data on the drive.
But, from that point on Windows Update would not run successfully. I had updates configured to run auomatically, so it was not a browser problem as such.
It took a lot of searching around, but I finally found a page in MS's support area that revealed my problem - restoring Windows from the disc was known to prevent future updates from installing. There were detailed instructions on how to fix the problem. Updates are now working again.
Googling your error turned up this page (among many others) that looks like it has some useful suggestions:
http://www.cforum.net/forums/t242075-0x80200010.html
Hi all,
thanks for all your help.
Updates completed.
But, I'm still confused.
Updates failed twice on 1.3.8.
Today (5.3.8) I disabled AVG and 2 updates installed successfully.
But the 11failures did not show up.
Looked back at history and found that the 11updates that had failed on 1.3.8 had installed successfully, unattended, on 2.3.8.
AVG is switched back on.
I wonder if I tried to use Firefox for update, but that MS update uses IE?
Updates completed.
The browsers are supposed to be compatible. HTML is an open standard. Perhaps MS has their own reason.
just used MS update to install IE7 with AVG still switched on.
Successful.
Spybot intercepted some registry changes and I accept them manually.
Successful.
jnb said:The browsers are supposed to be compatible. HTML is an open standard. Perhaps MS has their own reason.
Microsoft update isn't pure HTML. It is designed to only work on MSIE. They run a bunch of tests etc to try to verify the authenticity of your windows installation and I assume that they use proprietary API's only available in MSIE to do this.
MSIE has traditionally been a generation behind the current HTML specs and bloated full of M$ only API's.
AudioFreak said:Microsoft update isn't pure HTML. It is designed to only work on MSIE. They run a bunch of tests etc to try to verify the authenticity of your windows installation and I assume that they use proprietary API's only available in MSIE to do this.
Hence the link I posted above for non-IE browsers. 😉
This is my point, though I didn't word it well. MS update functionality theoretically has no place being in a browser.
Browser features, too 😉
Did you read 'Zoo' a couple of months back in their back page trivia section where it was listed that the internet was invented in 1993?
update problem again
I tried to update my XP3 machine, but it refused.
This machine is misbehaving so I just thought there was an error in the operating system.
Tried again a few days later. same refusal.
Today I tried to update my Win7 pc.
It reports back that service not available.
What do I check on the Win7 PC?
The Win7 pc has been down for about 9months waiting for the retailer to sort out a replacement PSU.
I think it was working before it died.
I can see a history of updates dated last september,
Mr T,
How are you? It's been a long time since we spoke!
I can't help with 7, but XP (which I'm still using)... Hopefully I can help.
Are you using McAfee virus software?
McAfee recently released updates that messed up millions of PC and ISP's. (OUCH)
Is the XP machine able to go online?
I do hope all is well with you!
OK, it's been a long time without any Internet connexion.
Have you checked your ADSL/Box line ? Is it Ok ?
If yes, try this :
Start / Execute : type "cmd" -> a black window box should appear
Within it when prompted, type : "tracert www.diyaudio.com"
Please report the answer
PS : 9 monthes for a PSU replacement... hope it's a hand made unit 😉
If yes, try this :
I am using the Win7 pc to write these last few posts.
It goes to Google OK and to here.
I have been using the XP pc exclusively for the past while and seeing it getting slower and slower. I want the Win7 PC working properly and then I'll try to copy across all my old data and redo the old PC to win7 spec. That's what I wanted to do when I bought the win7 pc.
- General Interest
- Everything Else
- windows update failed
