This may lead to clipping.
From the posted sch, I can not find the gain setting of the LPF(Not IV, a mistake in the title. The sch shall be a first order LPF plus a second order LPF) as well as the voltage of the positive supply.If the maximum output voltage declared by manufacturer (NAD) is 2.2V RMS, the opamp have not way to clip. Correct?
Not sure if it was a mistake in the title, but I think this is a voltage output DAC so that's not an IV op-amp.
