Because of phase shift in the crossover.
See also here:
http://www.diyaudio.com/forums/multi-way/234465-drivers-out-phase-2-way.html
See also here:
Yes, all normal filters have phase shift, electronic, passive, active digital, analog, acoustical. There are ways with DSP to flatten the phase, and that has become something of a new approach or a fad. But most filters you'll encounter will have phase shift.
If you have a copy of MicroSoft Excel I highly recommend "Passive Crossover Designer" by Jeff Bagby. Spending time with PCD will teach you a lot about how filter work.
thanks i will try it ,i want to learn more about filters , i do prefer the mids reversed , they sound less forward easyer on the ear.
Having a mid (or any driver) with opposite polarity is completely dependent on the specific speaker/crossover design. You cant just randomly flip the polarity
Having a mid (or any driver) with opposite polarity is completely dependent on the specific speaker/crossover design. You cant just randomly flip the polarity![]()
My Camm Dynatone 2-way speakers have the same polarity by manipulating the values in the crossover calculation.
Anyhow, it was an interesting observation regarding absolute phase.
Assuming that absolute phase is not audible, then
Woof(+) Mid(-) Tweet(+) is equal to
Woof(-) Mid(+) Tweet(-)
But often/usually/ime Woof(+) sounds better/louder than Woof(-).
In many 3-way cases, the midrange driver is too sensitive and cannot easily be padded down like tweeter to match the woofer insensitivity. This brings harsh or too forward sound so Mid(-) might be preferable than Mid(+) (may be audible only to batman
But if the design requires the same polarity between woofer and midrange (for example Woof+/Mid+/Tweet- or Woof-/Mid-/Tweet+), may be I will prefer to prioritize the woofer to have the favorable phase.
i was just trying the minidsp
- Why do so many designs have midrange fase reversed ?
