my friend said that when you design a (sealed) enclosure, it is better to make a paralellogram type box (where either the back piece of MDF or mounting piece of MDF is at an angle) rather than a square box (all 90 degree angles) because it takes a little bit longer for the sine waves coming off the back of the subs to reflect back at an angle to the back of the subs, thus creating some disonance because the sub will be producing a diff freq by the time it reflects back(considering it changed freqs). why is this good?
what angle is most preferable? rather, which will create optimum performance?
also, if anybody has designed a good box for two 12" Infinity Kappa Perfect DVQs, please let me know.
or if you're super cool and want to design a simple box for me, please do! mounting depth = 7" (178mm). cut-out diameter = 10-7/8" (277mm). compliance volume Vas = 3.31 ft3 (94.28 L). and [i dont know if you need this but just in case] free air resonance Fs = 22.01Hz. space is not an issue.
