Which plate amp?
Hi Martin,
Before you get started, you are wanting a couple of 12" pro drivers for a sub? I don't remember off hand but I dont think the Delta's go below 40 or 50 Hz. These are high efficiency, low Xmax PA drivers.
Is this for loud music or were you looking for a sub?
Also, that amp is quite weak for two high powered pro drivers. You might consider a bigger one like the 500 or even the 1000 watt unit at PE
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-808
Please tell us more about what it is you are doing.
Cal
BAD IDEA
Whoa, hold on there a second!
I need to say that it is an extremely BAD idea to EQ low-Xmax drivers for deeper bass response. Since the voice coil is so relatively short, you will run it outside the magnetic gap in no time, causing a HUGE increase in THD and an even BIGGER decrease in sound quality. I would bet money that you won't be _half_ as impressed with those two 12" pro woofers as with ONE AESpeakers AV12 SUB-woofer. They're on special now at the AE Speakers online store, and I think it's for even less than you would be paying for the two pro sub drivers. The AV12 also has the reputation of being one of the cleanest-sounding bass drivers on the market, and I can tell you from personal experience that it is one great driver for music.
But for corn's sake, pick a real subwoofer driver! The course of action you are describing is an extremely bad recipe for a subwoofer, and a very good recipe for real disaster! Don't waste your money doing it again - make sure it's right the first time.
If, after you read this, you are still set on the pro drivers, I can't really stop you, but I needed to make sure that we have a reality check: Pro sound drivers make terrible subwoofers and only marginal woofers for high-fidelity applications.
Re: BAD IDEA
Please identify your personal opinions as such, and not "reality". There are a lot of respected designs using pro drivers and MANY would argue that they are superior drivers for hifi because of their higher efficiency.
Joined 2002
Apex "SENIOR"
I'm selling a sub-woofer amp in the middle
350 Watts at 4 ohm and 250 Watts at 8 ohms
The Apex "Senior" There priced at $159.95
I will offer a DIY Audio special deal till the end
of June at $145.00ea, plus shipping.
Just mention DIY Audio when ordering.
Information and plans are on the website under amplifiers
Steve @ Apex Jr.
www.apexjr.com
Re: Apex "SENIOR"
Steve @ Apex Jr.
www.apexjr.com
E-mail me dude. I havent ordered from SOlen yet for amps. If you have all the goodys i would be interested in two.
Hi BAM,
Yes you are right. I know everithing you metioned, but everyone who listened to it tell you it is great... Originally it is used in Bastanis Prometeus speakers : http://www.bastanis.com/diy/prometheus+mkii_en.htm . The driver you suggested looks good but I don't like the high MMS (280 g). Isn't it too much for 12" driver? What do you think about Adire Shiva or NHT 1259?
Thanks Martin
