I am looking for recommendations on a nice enclosure for preamplifier I am building. I would prefer pre-drilled one with two knobs (one for source and one for volume). There are couple on Ebay but either they have logo/text I do not need or description is too vague that I do not even know what diameter the holes are.
Thanks.
Thanks.
ebay is still an excellent source for cheap pre-made amplifier cases.
A couple of examples:
DIY BZ3608C Full Aluminum Enclosure Amp Case Power Amplifier Box Chassis | eBay
2015NEW Aluminum Chassis DAC Amplifier Case Pre Amplifier Enclosure 430x70x308mm | eBay
NEW silver full Aluminum preamp Enclosure AMP case power amplifier box chassis Y
maurycy:
You may be interested to know that there have been a few threads concerning how to remove logos from anodized aluminum. I believe one of the favorite methods is to gently rub a sugar cube on the offending ink. You may also want to consider siliconray, who's a member and vendor (Siliconray Online Electronics Store - diyAudio).
Regards,
Scott
Regards,
Scott
I really like this
Rounded aluminum chassis amplifier case silver enclosure DIY house 356X84X316mm | eBay
But a great source is to buy a second hand or faulty preamp which you like the look of and strip out the internals and build yours into it. If you pick the wrong one it may entail quite a bit of work but it's p to you if it's worth it in the end. I built mine into a Bang and Olufsen beocord 5000 cassette deck, took more work than I anticipated but I'm pleased with the result. I also got another front panel which I fitted to my DAC.
B&O Beocord 5000 Cassette Player - Tape Deck - Bang & Olufsen - Type 4922 | eBay
Would have been easier if I'd picked a pre-amp to begin with!!
Hi.
Have you look at The diyAudio Store – diyAudio Store (BETA).
They have nice enclosure and can do customization on your panel.
