Where to find banana connections
Can you make do with using 4 stackable banana plugs for every pair, using the second pair as surface mount sockets and making the face plate yourself?
Neither CPC nor Farnell (I don't know if either of them ship to US anyway) have pre-fitted face plates, but they have blank face plates you can drill your own holes in and banana connectors you can surface mount and stack together (ie. in this formation-)
Found a couple possibilities for you:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-309
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-307
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-314
Personally I'm a fan of the last one, especially when used on subs, look at the dimensions on the website.
Edit: Theres also a number of terminals on parts express that look identical to the picture that you've shown, but they are indeed gold plated, if you'd prefer the plastic shroud.
