Hello.
Try here:
http://www.buerklin.com/default.asp?l=e
They have FTcap GM series. Low ESR and great for audio
Try here:
http://www.elfa.se/en/ has the Rifa PEH200, 100V 22000uF and 47000uF.
Not the cheapest caps around though.
You can get Rifa caps for very cheap at www.svalander.se
You will find it hard to find better or cheaper caps than those (when bought from svalander, otherwise they are very expensive)
Magura
Magura
Thanks for all the kind and useful answers!
Unfortunately, all those 22.000uF 100V capacitors have a diameter of 65mm when my amplifier internal space is only prepared for 4 caps of 55cm diam. max (height can be any).
Meanwhile I've seen in Panasonic's international/american catalog that they have 22.000, 27.000, and 33.000uF 100V capacitors only 50mm thick (2 inches). Unfortunately, I haven't found this series selling anywhere in Europe.
- Panasonic Part Number EEGAA2A223FKE
(22000uF 100V diameter: 2 inches)
- Panasonic Part Number EEGAA2A273FNE
(27000uF 100V diameter: 2 inches)
- Panasonic Part Number EEGAA2A333FPE
(33000uF 100V diameter: 2 inches)
- Where to buy large caps in Europe?
