Hello
Where do i get the best bargin on 10000uf 100V 85 or 105 degrees C capacitors of good quality?
The price is of matter, because i need 28 of them.
regards
el_mariachi
regards
el_mariachi
Except ELFA (from which i get only special capacitors such as SCR or WIMA polypropylene foil) take a look in http://no.farnell.com/ which offer Panasonic or Nichicon electrolytic capacitors of any quality you want. Especially the ECA series of Panasonic are proposed for audio use, but also the Nhichicon are of the same quality in use at Power supplies as i suppose you want because the values you refer.
Fotios
Fotios
It may be a problem since Farnell doesn't sell to private persons.
If anyone in Sweden wants to buy from Farnell, send me a message and I can fix that.
peranders said:It may be a problem since Farnell doesn't sell to private persons.
Then you can make your order fromhttp://export.farnell.com/jsp/home/homepage.jsp?_DARGS=/jsp/home/exportHome.jsp_A&_DAV=en_EX_DIRECTEXP. Try it and maybe you can make your job.
