I am rebuilding (repairing) the bias supply for an Acoustat electrostatic speaker and I need at least 1 but preferably 2, 500-Meg, 2W resistors.
I would also like to replace 4, 10-Meg, 2W resistors.
So far, I cannot find a source for these unless I buy 1,000 pieces and wait 8 months and spend a few thousand dollars (per Mouser and Digikey and general Google search).
Are there any sources for these?
I did find some 1-Gig, 7.5 W resistors ($10 each) at a local shop and I guess I could get two and install them in parallel. They will fit.
Sorry if there's already a thread on this - I did search here too and could not find a thread.
Thanks,
Terry, SF Bay Area
Thanks,
Terry, SF Bay Area
Don't forget the voltage rating.
You often can buy small sample quantities direct from the mfr or through their sales rep (esp in CA).
** NEW ** High Voltage Axial Resistors (HVA Series) | Ohmcraft
https://riedon.com/media/pdf/HTE.pdf
Caddock's Precision High Voltage Resistors
Ten pieces from Onlinecomponents or TTI looks good. These are rated at 15kV.
SM108035006FE Ohmite datasheet and CAD model download | Octopart
Thank you. I need to work on my Mouser search skills, I guess.
Thanks!
- Design & Build
- Parts
- Where Can I Find High Resistance, 2W Resistors?
