When paralleling opa549
I'd very strongly suggest using something much larger than 0.01 ohm. Like to 0.1 ohm to 0.5 ohm.
With 0.01 ohm, even a difference of 10 mV will cause 1 amp of current to flow between the amplifiers. Think about it... if at any instant, one amp is outputting say 25.490 V and the other is 25.480 V (only a 0.04 % difference!) then you get a significant current of 1 A flowing between the two amps. This is completely wasted power creating heat rather than music. If the gain of the two amps is matched even more poorly, say to 1% (which is actually quite closely matched), then you could get some major problems with 0.01 ohm. With one amp outputting 25.000 V and the other merely 1% higher at 25.250 V, you would get 25 A of current trying to flow between the amps. Of course, either the current limitting of the amp will kick in long before that (causing distortion and greatly reduced power output), or if you've chosen not to use the current limitting, the chips will go up in smoke. And everyone knows that once the magic smoke gets out, you can't put it back in.
