Did I messed up the twister board?
Followed the build guide and aligned the switch notch with the "+" mark above the "C6" on the board but the whole assembly now does not fit onto the front panel. Everything seems to be rotated for 180... Am I missing something?
just cut that notch with pliers
or drill new hole in front plate
switch is good, even if rotated by 180deg
Interesting. Also the notch hole is too far away from the center of the switch hole so even if the orientation was good the notch pin doesn't fit. I would say for about 1 - 1.5 mm. 🙂
@Gianluca maybe you want to take a look at this. I saw this exact problem on two front plates so far...
Uhmmm this is quite strange indeed as that is the exact same file we have used many times and it has not been changed and it's the first time I hear about this issue
No problem, there is a way around this...Uhmmm this is quite strange indeed as that is the exact same file we have used many times and it has not been changed and it's the first time I hear about this issue![]()
Just for the future builds you may update the drilling pattern if you like...
Thanks!
- What's wrong with the kiss, boy?
