I've been reading a lot of articles about how different people have gone about building their DIY amps/preamps. I now know the huge difference capacitors in the signal path can make but what about resistors?
I have seen reference to Holco and caddock brand resisitors. What is special about these (presumably high quality) resistors? Are they just tighter tolerence types (ie. 1%). Will I hear the difference these resistors will make when substituted for the standard types (ie. 5% metal, 5% carbon)?
I live in Australia and as yet have not come across anything but the standard type resistors does anyone know where I can get the aformentioned brands or equivalents either here or overseas.
Cheers
Dan
Cheers
Dan
ding,
I don't know that the brands you mention have necessarily better tolerances or thermal stability. Mostly it has to do with '" " sound " ". Don't expect to find this stuff at big places like Digikey and such, the only people that care about this kind of crap are " " audiophiles " " and that means buying from some outfit like Welborne labs and others. Bottom line: get ready to get sucked out dry.
Dan
I'm not going to get involved in a debate on the audibility of resistors since there are many conflicting views. Some people prefer carbon, some metal film and some pay unjustified prices for esoteric devices. Personally, I don't think there is as much difference as there is with capacitors so I use standard 1% metal films (though I have tried Holcos).
The reason for replying to your posting is to give you a couple of UK suppliers, in case you can't find one locally.
http://www.audionote.co.uk/
http://www.audiocom-uk.com/index.html
Audio Note have high quality metal film and tantalum resistors and Audiocom stock Holcos and Caddocks (amongst others).
Geoff
Geoff
Is it worth it
Is getting "sucked out dry" worth it or is it just spending for spendings sake.
Dan
Dan
Dan,
As arguably one of, if not the highest profile "audiophiles" in these parts, I'll have to weigh in as...an agnostic, of all things. I have done fairly extensive comparisons of capacitors in the past, but have not done any serious work with resistors. People whose hearing I trust seem to consistently indicate that Vishay, Holco, Caddock, et. al. sound better than garden variety resistors. Not having done the routine myself, I will not venture to say either way. However, I will go on record on caps, as I've done my homework there.
Some caps are audibly superior to others. Period.
I see no reason not to believe that the same would be true of resistors, but as to paying $10/ea. for Vishay...I dunno...there are an awful lot of resistors in your average piece of audio gear. It'd have to be a pretty noticable difference. On the other hand, I just got in a batch of MIT caps, and they ain't cheap. I choose to pay (yes, dearly...) for the sound quality. Is it a linear relationship; is a $20 cap twice as good as a $10 cap? No. It's the same as everything else in life--a case of diminishing returns. How high up the curve you want to go is up to you (and your wallet). Even as fanatical as I get sometimes, I don't look down my nose at people who don't (or can't afford to) buy the expensive parts. I've been poor before, and may be again. Right now, I can (oh, so grudgingly!) pay the price, and so I do.
Why haven't I done my 'homework' on resistors? (And by extension, why haven't I updated my studies on caps? [At this point several years out of date.]) Time. And money, to a lesser extent. It's damned time consuming to swap parts in and out of a circuit. The alternative is to build two (or more) identical circuits but with parts from different manufacturers. That's faster, listening-wise, and you can A-B to your heart's content, but then you get into questions like,"is the bias on this circuit really quite the same as on that one?"
Ugh. It's enough to turn one into a numbers critter due to the number of variables.
For the time being, I console myself by using good caps, and pretty decent resistors (Vishay/Dale--Vishay now owns Dale, but do not confuse these with the Vishay resistors mentioned above. Vishay is a large company that's bought lotsa other companies--Sprague, too, I believe, and Siliconix.). My reasoning here is that resistors are *much* more consistent in size than 'audiophile' caps. I can do a board layout for a 1/2W resistor and be fairly certain that a wide spectrum of other resistors will fit in the same space later. Unfortunately, the same is not true of caps. I have to bite the bullet and get the expensive stuff right out of the gate, as the layout will change depending on whether you use Infinicap, Hovland, MIT, or whatever.
Sources:
http://www.tubesandmore.com (Hovland on sale)
http://www.mouser.com (Vishay/Dale)
http://www.bainbridge.net/percyaudio (Vishay, Roderstein, Caddock, others)
http://www.sonicfrontiers.com
http://www.hndme.com
http://www.welbornelabs.com (generally higher in price than everyone else--but mentioned above by grataku, thought I'd throw in the address)
There are others, but these are a representative sample. Roderstein resistors aren't too pricey, as these things go (I think Audio Research used to use them, may still for all I know). Vishay is probably the worst. The Vishay/Dale are reasonable (actually cheaper than I can buy NTE stuff here locally). Geoff and I (and others) are in agreement--the prices aren't justified in terms of what goes into the parts (true for caps, too). But nobody is making you (or me) buy the stuff. It's a market economy. They offer at a price and you either buy or not, as suits you.
Two notes:
-Don't use Hovland resistors over 200V or so. (Kinda limits tube applications a bit.)
-Compare prices. Not that you wouldn't, but some of the suppliers kick in discounts based on quantity, others based on dollar amount. Make up a detailed list of what you might want, then run the list through the mill. Surprises sometimes fall out when supplier "A" suddenly drops 5% because you went over $150, but supplier "B" gives a 25% discount because you want 10 pieces.
But, Grey, is it *worth* the money? Really?
Sorry, Grey ain't here...he went out for a beer. Leave a message so he can ignore it when he gets back in.
Grey
Sources:
Two notes:
Grey
Hi End Resistors
One of the areas that these high priced resistors excel at are a rating called ppm. I forget what it stands for, it's not parts per million...I think, Anyway, what that rating indicates is the change in value for a given rating /watt over time. All resistors begin to change in value when current passes through them after a long period of time. Typical resistors, 1% metal film, have a ppm of 50 to 100, Vishay has something like 5 ppm or less. Caddock is only a bit higher. Both considered excellent. Some say that it's like having nothing in the signal path, like a straight wire. Vishay are something like $10.95 for a typical value here in the States. Caddock are about $4.00 for the same value, and are just about as good, at least that's what Micheal Percy says, a seller of DIY parts in CA. I have not ventured to buy these parts..yet.
I always wanted to build a simple circuit like the Zen with high end resistor and normal 1% to see if I could here a difference. Oh, and the tolarences for these are better than 1% too.
BTW- There is a Vishay facility about 4 miles from where I live. I once called for some samples; they didn't send any. I guess they only like to deal with areospace co's and the military. Elitist snobs! 😉
Vince
Vince
ppm IS parts per million.
It's called temperature coefficient, and really good
resistors (metal film and wire wound) will have lower values over both short and long term. Another figure of
merit is low noise, but generally metal film and wire wounds are the lowest anyway. Anything under 50 ppm seems to cost a good bit more. Better quality parts seem to be
of more robust physical construction too, especially for
wire wound types.
So-called tantalum resistors seem to be regarded as the very best types, but are almost impossible to find at any price. I think these are tantalum nitride, and may also be available in surface mount parts, but I'm not going to fool with that unless I absolutely can't avoid it.
Mills has a very good reputation for wire wounds, but I think any part of good physical quality and low temperature coefficient is good enough. I was going to use Mills for
emitter resistors in my Leach amplifier upgrade project, but I found good-quality substitutes locally (IRC stamped) at a lower price. I deconstructed one and found the resistive element was a relatively wide tape rather than a thin wire, which suggests a better temperature coefficient than the sand cast types I'd been using for my projects.
Lower internal inductance is a Good Thing, and possibly
non-magnetic construction throughout, but these qualities
are difficult to find in most parts and I don't worry overmuch about it.
Some types of resistors seem to be midway between metal film and wire wound, such as the bulk foil types. As I
can't afford to spend several dollars on individual resistors (other than high power wirewounds for very specific applications), I happily settle for metal film
resistors of most any sort. I think Vishay/Dale CMF55/60 types have been well-received and are available through Mouser.
As has been pointed out, some people like the sound of a good quality carbon composition resistor, but these have gone out of production and the best ones, Allen Bradley I think, are getting very rare. They don't age too well, either.
We could get into potentiometers; there's an area where I don't know of many specific good quality parts at reasonable prices.
wire wound types.
All other things equal ....
All other things equal, a component that is not itself magnetic (magnet test) is very likely to sound better than one which is.
Electromagnetic "forces" are very much stronger when in the vicinity of magnetic (magnetizable to be simplistic -- there are 3 main types of magnetism, ferromagnetism is the "worst" one which we are identifying by this test) materials.
Bring a magnet to the store when you buy. I got this tip from Thorsten.
Petter
[Edited by Petter on 06-15-2001 at 04:00 AM]
Petter
From memory Holco M-F resistors are a copper alloy with non-magnetic gold plated end caps, they are aged for 3 days at elevated temperatures then the values are checked, this weeds out the early failure high drift units, and justifies the premium prices (?).
As you are in Australia (I'm in Victoria) the best source I have found for quality and price is Radiospares
http://www.rs-components.com.au/
Last time I purchased reisitors form RS they were from italy, I think by Seci, at A$0.07 each (min 10 of each value) they are good value.
Most of the importers want you to buy 100 or 1000 of each value, at maybe A$4.00/100 with a minimum order of A$50.00.
I think they scored fairly well in listening test in Hi Fi news years ago.
Regards James
Regards James
I seem to remeber some major change that was made to Holco metal films resistors in the last year or so that made them no longer desirable - maybe using steel in the leads now or some ferrous metal in the endcaps? Now where did I see this: Sonic Frontiers parts catalog maybe? Anybody else remember this?
Michael
Michael
Holco Resistors
Michael,
I believe that you are correct, Holco changed construction because their older version was not mechanically stable, but the new version does not sound as good for reasons that you stated.
Jam
Michael,
Jam
Caddock resistors are available with higher power ratings then you can normally find elsewhere (up to 100W metal film). I would consider using these as emitter resistors.
The Holco and Vishay resistors are available with very tight tolerances. This might be useful in the differential amplifier of an input stage; they might be overkill too. Imbalance here can be a source of distortion. The question is how close does it have to be to drop under the noise floor?
Finally, I think Vishay claims that their resistors create VERY little noise. I don't know if this is significantly different from other resistors, nor do I know where the noise level of resistors is WRT the noise floor, but I'd bet that you don't have to worry about it until you're under .001% THD+Noise.
Good luck.
Good luck.
Ok now I can make a reasonably educated decision. I think I will continue to use the garden variety, 1/2W, 1%, metal film resistors I can get easily and cheaply from the local electronics store. I will continue to invest my hard earned in more performance/dollar components such as capacitors.
Dan
Dan
first, let me say that i agree with most everything that has been said here, except the part about resistors not sounding different or being relevant. they DO sound different. if a piece of wire can sound different (and i believe it can), then a resistor definitely can.
dan, are you sure you can't find suppliers of Roedersteins or something similar rather than generic metal films? if it is a pain in the next to get "audiophile"-type resistors, than by all means just go with the generic stuff, it is probably not worth the trouble. however, i think upgrading resistors is definitely a worthwhile improvement. i have tried Holco, Roederstein, and Caddock, and find them more transparent than more generic metal films. sometimes i burn out a resistor and don't have a Holco or Roederstein around to use so i stick a generic metal film in. ouch. the sound, even with just a couple resistor replacements, definitely goes down a notch. typically what i hear from generic metal films (and even to some extent some better ones) is a thinning-out of the sound, a bit of brightness and hashiness in the treble, loss of depth and dynamic impact, etc. etc. basically, it just sounds worse all-around.
the first resistor upgrade i did in my Rega integrated amp was to go with all Roedersteins. They are not regarded as the "best" resistors but actually sound quite good, not as clean as the super-expensive types but with a nice tonal balance. next i tried some Caddocks in my MSB Link DAC in critical locations, along with Holcos in other locations. Nice, very crisp and clean, but you need to be careful. Caddocks by virtue of their transparency can bring out a lot of HF energy that you didn't know was in your circuit so it can sometimes brighten up things a bit, at least so i have found. it'll also improve your bass and dynamics though, so that compensates a bit. Caddock MK-132 has good specs (low temperature/voltage coefficient) and probably have very low parasitics as well. they are also expensive, but not as bad as Vishay which i feel are just too expensive to be practical. next i tried all Holcos in an amp circuit, but was a little disappointed... they sound a little dry and have a bit of harshness or brightness. i noticed that they are not using copper leads anymore, as someone mentioned, but it doesn't seem to be steel as it isn't magnetic. whatever it is, it doesn't sound so great, and i think i may prefer Roedersteins after all. As far as power resistors go, i like Mills wirewounds, although i think wirewounds are a little more uniform in sound quality than metal films. some of the better IRC and Ohmite parts work just fine, just look for the best specs (low inductance, high tolerance, low temperature coefficient, etc.). wirewounds have a nice natural sound, better in some respects than metal films, so i don't feel there is a need to go with expensive power metal films unless you need absolute lowest inductance or highest precision.
i think the key to picking resistors is to see what part of the circuit they are functioning in. if it is a super-critical location like in series with the signal line or in the feedback loop, then go with the best resistor you can get (i use Caddock MK-132). if it is not quite as critical (shunting, current sourcing, etc.) then you can get away with a good but less expensive resistor (Roederstein, Caddock). If it is a higher-power application, go with a good wirewound (Mills, etc). at least, this is how i like to do things.
marc
marc
Welwyn?
I am currently building an Aleph 5, TDA2050 & LM3875 chip amps, and have choosen Welwyn RC55C
metal film +-0.5% 50ppm metal film resistors. They are not too expensive and are easily available.
Has anyone any experience with these ressitors compared to Cadddoc, Holco, Vihay, etc? How do they sound?
Btw. I use Farnell as my supplier. I have found the service and product availability to be excellent.
-Kaj
-Kaj
Recently found out that RS now source their 1% Metal Films from Taiwan now, might as well go to Jaycar 🙁
Farnell(Aust) stock Philips 1% MFs which are made by Beyschlag, I think they are the same as Audio Note sell as entry level.
<center><font face="comic sans MS">Regards
James</font></center>
Borbely audio still has some tantalum resistors left although im not sure of the specs . I ordered them with my lineamp cards from him . Didnt measure any specs from it but a few people are real proud of them . I use dale rn series ever since i built the SOBOZ preamp 🙂
It was reported on pg.25/26 of Stereophile, April 2001 issue by none other than Ben Duncan that Meggit plc(UK) have changed the construction of their Holco resistors for all time. Reportedly the maker had experienced minor but nagging problems with reliability. Now they use steel-based leadouts and endcaps-paradoxically to maintain "quality" for the majority, non-audio users. Hence, Holco resistors are no longer non-magnetic and according to the report are far less good-sounding.
I remember reading a report on a Passive Attenuator made by a French company, (Electrocomp...something) that they use a certain type of Vishay resistors which have an extended smooth high frequency response.
Here in India, I do not have easy access to all those brands of resistors that you folks are talking about; however, in my experience, good quality CFRs have a warm sound as compared to MFRs but their noise floor is higher. On the contrary, MFRs tend to sound a little leaner but their noise floor is lower. Noise becomes significant when the distortion figures are approaching the limits as well as in the case of Phono preamps. But for qaulity audio amplifiers I tend to stick to MFRs, due to their long term stability. Someone has already mentioned about PPM etc.,
Vote for Philips (BC)
I always use Philips (now BC components) MRS25 series, 1%, 0.6W devices. I prefer these to the Welwyn parts.
They sound pretty good to me and are cheap.
Available from Farnell, amongst others.
Andy.
Andy.
Resistors
WHAT A LOAD OF CRAP
I do belive that one can hear subtle diffrences, that are measurable.
I set up a straight forward voltage divider on a piece for veroboard with signal cable, for both Left and Right channels etc. First i fitted metal film type resistors, and listned, then i changed them for carbon types, do you know what i heard diffrent. NOTHING.
I also tryed to measure the inductance of said resistors (1K) it was unmeasureable, even on a hi performance HP meter!
I work in the calibration industry, where voltages are much lower AC and DC and metal film is fine, just the use of 15ppm resistors in major parts, such as current sence and gain set.
I think you are subject to anal retention and should check out D Self's site for a reality check.
WHAT A LOAD OF CRAP
- Whats the deal with resistors??
