good question and cool old patent! -- we'll have to dig deeper - if its possible at this point in time. It could have related to a whistle or perhaps a cut in an organ pipe - - ? maybe he saw or had one of those nozzles??
Karlson's first microwave antenna patent of the 1940's was a variable beamwidth type of conventional parabolic design. In his 1964 radio appearance on HiFi Workbench hosted by Eric Towline (Mr. Towline is alive and working in film and tv), Karlson described K15 basically as a coupled cavity type with improved matching and dispersion characteristics.
1964 radio show with John Karlson - his K15 cabinet was used extensively by the Ford, GE, Disney
and other World's Fair exhibitors
https://archive.org/details/KarlsonHifi64
The original Karlson K15, finalized in the summer of 1951 is superior in ways to horns for its bulk and use as a wide bandwidth reproducer. (Steve Schell part of Cogent will attest - lol)
There's a missing patent - or something was made possibly by Sperry without giving direct credit to Karlson. Wayne Green had a falling out with Karlson but did say John had invented an antenna upon which things were based)
KR5 Rocket speaker ad "Patented by J.E. Karlson, leading radar systems engineer, microwave specialist and inventor of a widely used Navy antenna"
[IMGDEAD]http://imagizer.imageshack.us/a/img809/3239/rocketsheetfront.jpg[/IMGDEAD]
Karlson's antenna reference seems missing - the late Wayne Green says he gave the idea to Karlson to make a speaker using the principles.
Here's an early V-notch antenna - the so called Vivaldi antenna is credited to Peter Gibson in 1978
Karlson's Open End Waveguide Antenna patent 1968 - this was concurent with Karlson's
X15 speaker which employed a similar slotted waveguide.
[IMGDEAD]http://img43.imageshack.us/img43/1174/openendp.png [/IMGDEAD]
one excellent audio example of that waveguide
[IMGDEAD]http://usr.audioasylum.com/images/4/44410/Karlson_The_Tube.jpg[/IMGDEAD]
KARLSON AND KARLSON-RELATED SPEAKER PATENTS
KARLSON PATENTS:
J.E. Karlson US 2586827 “Directive Radiating System” Filed March 31 1945 - a
Parabolic dish microwave antenna with what appeared to be a variable directivity pattern
J.E. Karlson “Acoustic Transducers” US 2816619 filed Dec. 1951, granted 6 years later - deals with broadbanding slot both in loudspeakers and musical instuments.
J.E Karlson “Acoustic System” US 2896736 filed Aug. 1955 - use of a modified Karlson laying on its back using either corner or wall to create a diffused sound image - HiFiLit’s website shows a K12 used in this fashion (laid on back) on the 1955 Karlson brochure page and Bose references this K-patent.
J.E. Karlson “Open End Waveguide Antenna” US 3445852 filed 1968 - essentially analogous with the K-tube waveguide used in Karlson’s X15 2-way speaker ~1966.
J.E. Karlson “Acoustic Transducers” - US 3540544 filed 1968 - concurrent with X15 and described Karlson’s use of ellipse based reflectors to improve the Ultra-Fidlety type via
Fig.6 and Fig 8’s reflctors (Fig6 upper reflector was used in the X15) and introduced the Asymmetric Projector with tapered elipse profile which appeared commercially as the AP-9C ceiling speaker - also- slotted microphones were discussed.
J.E. Karlson “Jet Engine Silencer Nozzle...) US 3543876 filed 1968 - jet engine muffler and rocket nozzles.
LIST OF INVENTIONS 4/24/50
J.E. (Edward) Karlson
1. ELECTRONIC POTENTIOMETER. A variable element which is capable of linear variations of resistances with infinitesimal mechanical motion yet also have capabilities of broad variations in resistance.
2. CAPLESS DISPENSING TUBE. This device permits the use of toothpaste tubes, etc. without the necessity and bother of removing and replacing the cap after each usage.
3. GEOLOGICAL PROSPECTING SYSTEM. A system for use in the prospecting for oil, minerals, etc. This system may also be used for radar applications.
4. RADAR ANTENNA WITH AUTOMATICALLY VARIABLE BEAM PATTERN. This invention provides a simple means of automatically changing the beam pattern of a radar antenna from a pencil beam to a cosecant beam.
5. DIELECTRIC ANTENNA. This invention provides a technique for designing commercial and military antennas which will have overall dimensions than conventional antennae, and yet have equivalent gain and directivity characteristics.
6. BRUSHLESS DC MOTOR
7. ASHTRAY. An extremely simple design for an ash tray which quickly extinguishes cigarettes.
8. PRECISION DELAY CIRCUIT. This circuit provides a delayed pulse at a precise interval following an initial pulse.
9. CHATTERLESS CONTACTS FOR RELAYS
10. TELEVISION ANTENNA. This invention provides a simple, low cost antenna which can be readily hidden or obscured in the average room and is suitable for both F.M. and television.
11. SLOT ANTENNA. This design provides a slot antenna with broad band matching possibilities.
12. HYBRID WAVEGUIDE JUNCTION. This is a wave guide section which has variable propagation characteristics dependant upon the direction of propagation.
13. R.F. TUNER. a simplified tuner for F.M. and television use.
14. ADVERTISING SIGN. Novel electric sigh with quick change possibilities.
15. LIGHT VALVE FOR TELEVISION PROJECTION AND PICKUP TUBE.
16. ACOUSTIC TRANSDUCER. A novel loudspeaker enclosure with improved matching characteristics and controlled reverberation.
17. FISHING DEVICE
18. TELEPHONE AMPLIFIER WITH SPECIAL ACOUSTIC CHARACTERISTICS
RELATED:
W.O Swinyard US 2020166 filed 1935 “Sound Reproduction Apparatus” - a wedge-shaped 20 degree coupler with “V” deflector having non-parallel walls
N.C. Fulmer US 2787332 filed 1952 “Loud-Speaker System” - a folded 1/4 wave pipe with last section broadbanded with tapered slot.
R-J Enclosure:
(1) "The R-J Speaker Enclosure" by William Joseph and Franklin Robbins. Published in Audio Engineering Magazine December 1951.
(2) "Practical Aspects of the R-J Speaker Enclosure" by William Joseph and Franklin Robbins. Published in Audio Engineering Magazine January 1953.
"Acoustic System for Loud-Speaker" US# 2694463; Robbins et al filed April 17, 1952 granted 11/54
(nephew of William) Jeff Joseph's Loudspeakers:
http://www.josephaudio.com/
J.J. Baruch US2766839 "Loudspeaker System" Filed March 16th 1953, granted Oct. 16th 1956 - deals with math of distributive resistive vents using round holes
- Marty Poppe built X15 copy of Ann Karlson's organ speaker using 42-0.375" holes to damp the system for a particular 15" woofer.
John A. McKenzie US 3590941 filed 1969 “Speaker Enclosure” - a dual mouth K-coupler like stacked “Asymmetric-Projector” having a final deflector at each mouth
Robert W. Reams US 4196790 filed 1978 “Acoustic Transducer having Multiple Frequency Resonance” - novel use of Karlson’s slot to create a broad-banded throat in a
PA-application quasi-scoop horn with sealed back chamber - Gregory Raw termed it a Sci-fi-scoop”.
Rodden, M. Raymond US 4313521 filed Feb. 2 1982 "Speaker Housing"
Sapkowski September 3, 1996 "Exponential multi-ported acoustic enclosure" United States Patent 5,552,569
Weiss et al US 5943431 August 24, 1999 “Loudspeaker With Tapered Slot Coupler And Sound Reproduction System” - basically a wedge-shaped asymmetric projector waveguide for 1” compression driver
