Im building a scale sized model of the solar system in my living room and looking for a 41 inch half sphere for Jupiter and a 33 inch half sphere for Saturn. Thought smooth foam would work but I'm looking at a $400 price tag for that!
Any ideas on what I can use in place of foam? thanks
The Sun, six times bigger than Jupiter? Not even close.
"The Sun's diameter is 864,938 miles (1,391,980 km). This is almost 10 times larger than the planet Jupiter and about 109 times as big as the Earth."
So the Sun needs to be ~34' in diameter for a 41" Jupiter.
I knew it was more than 6, but was surprised it was only 10. I think the difference between Earth and Jupiter is greater.
And BTW, switching to and from imperial and metric units is a breeze with Josh Madison's Convert program. It's free.
For those sizes I'd start with 3 or 4 half-circles cut from thin, cheap, plywood using my router and a circle jig. Attach some chicken wire or hardware cloth and form it to "look right". (A highly accurate sphere isn't required here.) Then cover it with canvas cloth or fiberglass fabric. (Auto body or boat repair shops may have the materials or give helpful advice.) Finish with fiberglass resin or several coats of polyurethane.. . . 41 inch half sphere for Jupiter and a 33 inch half sphere for Saturn. . . .
Dale
Start your project with the biggest object (Sun) scaled to something readily available of manageable size...perhaps a sphere of roughly 50 cm diameter. Then Jupiter and Saturn are 5 and 4 cm respectively, Uranus and Neptune roughly 1.5 cm and the rocky planets various sizes of shot.
- Design & Build
- Construction Tips
- What to use for spheres in scale solar system project
