http://pro-radio.ru/user/uploads/11566.pdf
this is a holton schematic and has D3 and D4 which connects between the output and gates of the output stages... Please scroll to the end of the acrobat documents...
what are those values and what is the use of those diodes there..
The diode is to allow the Vgs to go into cutoff. If it were not there, then the gate drive would only be able to go into cutoff 0.6V, or the value of a forward bias
Zener, limiting the time it takes to turn off the divice. The regular diode should be fine for such a general driving stage. I typically use two 15V Zeners in series stacked in opposite directions for this reason and to prevent Vgs from exceeding the 20V breakdown in either direction.
- what is the value of D3 and D4 diode in the sch and whats the use of them?
