I'm looking forward to building my first FR speaker after I finish my on going 2.5 way project.
There are 2 brands of FR speakers that always pop up on my mind, Tang band and fostex.
The main question is, What model is the best 4" FR driver under $100- from the 2 brands I mentioned?
Cost no object as long it is below $100- each.😀
The speaker will be used for my PC.
Dave's recc. is a good one, however, it's efficiency is about 4db lower than the FE126's/127's and about twice the price IIRC. Something to consider depending on your amp choice.
Don
Don
4 inch Fostex would be 103 or the shielded version, 107 and 108.
4 inch Tangband would be the bamboo or the titanium models.
It would be a good matchup imo, but one that will never prove a definite winner because they offer different sounds. All excellent but with different perspectives.
Fostex will be more efficient and more forward sounding while TB will be have fuller bass at the expense of efficiency. Either brand works well with inexpensive (but great sounding) digital amps. Add a sub to either and enjoy a great speaker system limited only to ultimate output.
I suppose the Jordan wins top spot for 4 inch full range drivers but i have never yet had the pleasure of hearing a pair.
A great comparison test would be Jordan vs Fostex vs Tangband in the best set of cabinets for each. Blind listening tests with Tube, SS and digital amps may prove interesting!
Godzilla
Godzilla
renjiish said:
They are!, but I should have added that the 126/127's are both worth considering IF the extra 1/2 inch makes no difference!DaveCan said:Don the 126 and 127 are 4.5'' drivers Dave🙂
Can't see why it would!
Don
My wife says half an inch can mean everything.
I think the 127 sounds a little fuller than the 103 but the 4 inch TBs sound fuller (but less extended on top) than the 4.5 inch Fostex.
Godzilla said:My wife says half an inch can mean everything.
The Fostex FX120 is $103 and an excellent driver. The FE127E is also very good and tough to beat given the cost.
So, Zilla, ever get those BiBs for the TB Bamboos assembled? I've always had a soft spot for those things, even though the prices have risen ridiculously, so I'd love to hear about them in a "real" enclosure.
Kensai
Kensai
Godzilla said:I suppose the Jordan wins top spot for 4 inch full range drivers but i have never yet had the pleasure of hearing a pair.
I just held my brand new JX92 up against FE127 and the Jordan is bigger,
Got the Jordans to see if the FE127eN can spank them (or not)
FE127 really is 90-91 dB
I've not yet been able to get FE108eS to be as good as FE127eN (or FE126eN)
FX120 & F120A are also here or coming
dave
I noticed that the majority here would recommend a fostex, which I also like. But how about Tang band drivers, Has anybody compared it with fostex?
I also like the Idea of getting 5" drivers , But my desk space is very limited.
Do I still need use BSC on FR speakers when placed on the desk and against the wall?
I've had pretty good results with the uber cheap TangBand W4-655sa, used them in a Cyburg Stick, Buschhorn, and a bookshelf horn. The last was obviously bass-shy, but the midrange is good enough. I'm not sure if they'll compete with ~100 a piece drivers out there, but they are plenty fun for the money.
The JX92s does give them a run for their money though...
Not yet. I have all the wood up against the wall waiting. Every once in a while i check to make sure i have all the pieces. I do. The Bamboo's still live in ported cabinets happily and serve me (and my family) very well indeed even without a subwoofer in my home theater rig. Everything sounds great with these (accompanying my 40 inch flat screen). I love the TBs for home theater! I prefer them to the Fostex because i can keep them smaller and get deeper, fuller bass. I think Fostex require larger cabinets to sound their best - and they do sound great in proper cabinets!
http://www.zillaspeak.com/Bamboo.asp
http://www.zillaspeak.com/4greatfullrangers.asp
I have compared a few Fostex with the Bamboo. I don't think my comments will show one driver to sound better than the others but i tried to describe their different characteristics. I own both brands of drivers (i also have 3 inch TB drivers (metal and paper cone). All the TBs have a similar sound as do the Fostex. Pick your poison i always say. Personally, i think it is easier to get good sound from the TB, the Fostex requiring some wiggling and jiggling with box design and placement.
BTW, if anyone is interested in my 165k BIB i would be happy to sell it to a good home. If i sell it, i can build the Bamboo BIB and listen to that for a while. The 165k BIB is an amazing speaker but i do not seem capable of a monogamous relationship with speakers. If no one wants them i will continue to listen to them happily. But i am trying to make room for other projects.
http://www.zillaspeak.com/bib-godzillabib.asp
Godzilla
Godzilla
Tangband W4-1052SD is an excellent sounding little driver. However, it's 4ohm and not very efficient (89dB 1W/1M) so it may not be the right choice in some circumstances.
The CS FR125SR look nice, has anybody heard them?
BTW, I'm wondering what the Fostex drivers' surround are made of, Cloth, rubber or foam. If foam , Will fostex repair them in the future when the foam rots?
The CSS FR125SR is a nice driver. Whether you choose it over a Fostex has a lot to do with the amp you are mating with it.
The FE series of Fostex have treated cloth surrounds. The really nice surrounds on the eSigma drivers (and FF85) are foam. Modern foam is not the same as the old stuff you see failing all the time.
dave
dave
- Full Range
- what is the best 4" FR speaker , under $100-?
